12-09-2014 02:27 AM
30 12
tools
  1. Gevio WhiteWizard's Avatar
    Hello guys , so lately i installed a swiftkey app but the original file is not free so i decided to get it from google as an apk file and i used ot for about 5 minutes cause i dont like it and when i connected my tablet to my pc i saw a txt file named keylogger and i saw there the things i typed when i was using swift key , why did that hsppen ?
    03-09-2014 02:58 PM
  2. Kevin OQuinn's Avatar
    Probably because you used a cracked version of the app instead of buying it from the Play Store.
    03-09-2014 03:01 PM
  3. wizzrah's Avatar
    Because you got it illegally...
    bobbob1016 likes this.
    03-09-2014 03:02 PM
  4. Gevio WhiteWizard's Avatar
    Yes but was swiftkey.apk a keylogger ? I uninstalled it immidiatly after i saw that txt file named keylogger
    03-09-2014 03:03 PM
  5. Kevin OQuinn's Avatar
    Given the way some of these cracked apps work, I would take some measures to ensure your passwords aren't compromised. Change them all. If you typed it on your phone, I would assume it's compromised. You have no idea what got sent where if that's a cracked app running a keylogger.
    03-09-2014 03:04 PM
  6. Kevin OQuinn's Avatar
    The official version of SwiftKey doesn't do anything nefarious with what you type. If you acquire an APK from somewhere other than the Play Store the possibility exists that it was opened up and extra code was put in there by a less than honest person.
    03-09-2014 03:05 PM
  7. wizzrah's Avatar
    https://play.google.com/store/apps/d...ey.phone.trial
    Swiftkey has a free trial. You could of used it for one month!
    SoreAintya likes this.
    03-09-2014 03:06 PM
  8. Gevio WhiteWizard's Avatar
    Yes i understand i used it for just about 5 minutes or less just tested it with a sms i texted to my uncle nothing else
    03-09-2014 03:07 PM
  9. Gevio WhiteWizard's Avatar
    I uninstalled it now , am i safe ?
    03-09-2014 03:14 PM
  10. Kevin OQuinn's Avatar
    I honestly couldn't say. Depends on what else it may have done when it was installed.
    03-09-2014 03:16 PM
  11. Gevio WhiteWizard's Avatar
    What should i do to get rid of it , should i factory reset my phone ? I am afraid from it
    posted via Samsung Galaxy Tab 3 , 7.0
    03-09-2014 03:26 PM
  12. dpham00's Avatar
    It really depends on where you got it. I installed the SwiftKey beta apk directly from SwiftKey's website, and I am confident in my download. But if you downloaded it from a less than desirable website, then it could most certainly be a problem.
    Btw, I got SwiftKey free legitimately a while back. If money is very tight that you can not afford to pay for it then wait and it will probably go on sale sometime, if you don't want the beta. Or who knows it might be free again, though not likely
    dpham00, Android Central Moderator
    Sent from my Verizon Sansung Galaxy S III
    03-09-2014 03:26 PM
  13. Gevio WhiteWizard's Avatar
    Its not the problem that i dont have money but i am only 14 and i dont have a credit card ... anywhay what should i do to disable the keylogger if it is active and i have an antivirus , why hasnt that found it
    03-09-2014 03:31 PM
  14. dpham00's Avatar
    Factory reset would be the safest thing. But they might have already stolen information, depending on what you typed. Can't do anything about it now though.
    You can buy a visa prepaid card with cash at a lot of stores. Do read the terms of course, there are probably fees associated with them
    03-09-2014 03:34 PM
  15. Gevio WhiteWizard's Avatar
    I only typed with it just a few lines , there is no information with that i typed. I have too many apps and i dont want to reset the whoole thing ...
    03-09-2014 03:42 PM
  16. dpham00's Avatar
    It isn't just key logging but who knows what else it can do. It might give them remote access to your files for all I know. And un installing might not remove the malware or virus
    03-09-2014 03:45 PM
  17. Gevio WhiteWizard's Avatar
    I factory reseted it a few days ago.. but ok i will do it again for my security ... thanks for your help
    03-09-2014 03:52 PM
  18. bobbob1016's Avatar
    As has been said, you stole the app.
    Not likely, probably a the place that gave you the stolen app added it there. They aren't stealing things for you for free.
    No one can tell you at all, we don't know what was installed, nor where. I wouldn't really help you, as I almost see it as helping theft.
    Anti-Virus on an Android isn't the same as on a PC, as it doesn't have to be. There is a *chance* that SwiftKey made this empty file on purpose to mess with people who steal their app. I remember GTA (IV I think) kept you in Drunk Mode if you stole the app.
    03-09-2014 04:24 PM
  19. Gevio WhiteWizard's Avatar
    I didnt mean to steal it i just wanted to test it and i didnt like it ....
    03-09-2014 04:32 PM
  20. wizzrah's Avatar
    But there is a free trial! It's okay, just learn from your mistake and don't do it again. A factory reset should be sufficient enough to clear the internal storage clean. After that, you should be fine.
    Kevin OQuinn likes this.
    03-09-2014 04:42 PM
  21. Kevin OQuinn's Avatar
    I agree.
    wizzrah likes this.
    03-09-2014 06:41 PM
  22. dpham00's Avatar
    I believe that in the kk update, Samsung only allows non pre installed apps access to all directories. Other installed apps can only access it's own directory. So before, an app can access and mess up other apps theoretically. That is why I recommend a factory data reset.
    I know many people complain about this, but personally, I don't think it is a bad thing
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    wizzrah likes this.
    03-09-2014 08:27 PM
  23. Rukbat's Avatar
    I'd still change any password of value (like Google Wallet, Amazon, your bank) just to be sure.
    03-09-2014 09:04 PM
  24. dpham00's Avatar
    Absolutely, you have no idea what information they took
    03-10-2014 12:34 AM
  25. Gevio WhiteWizard's Avatar
    In google i have my addsense account i dont want them to take this account i have a lot of money waiting to come i there
    03-10-2014 03:00 PM
30 12
  1. Why can't I hear the people I call on my Galaxy S4?
    By Connort226 in forum General Help and How To
    Last Post: 08-08-2016, 02:45 AM
  2. Problem attaching photo when in Forum!
    By Jalopiejoe in forum Site Feedback & Help
    Last Post: 03-10-2014, 08:25 AM
  3. Note 3 battery life subpar compared to my Note 2
    By HothTron in forum Samsung Galaxy Note 3
    Last Post: 03-09-2014, 02:52 PM
  4. Note 3 battery life subpar compared to my Note 2
    By HothTron in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 03-09-2014, 02:27 PM
  5. Replies: 0
    Last Post: 03-09-2014, 12:45 PM
