1. cheapskate12's Avatar
    I perused the play store looking for an app that will notify me whenever I connect to a specific wifi network but didn't have any luck. Does anyone know of such an app?
    and in case anyone curious why I'm looking for this functionality
    - i'm on a wifi only plan with my carrier
    - my work has a wifi network but it requires me to provide login credentials before it is useable, so I'll be connected to their wifi network but I often forget to login to make it useable.
    Hope that makes sense and thanks for your time
    03-10-2014 09:28 AM
  2. Golfdriver97's Avatar
    I think Tasker might be able to help. It is a paid app, but I think you can set it up by location to connect to your work WiFi.
    03-10-2014 09:35 AM
  3. SpookDroid's Avatar
    Yup, ditto on Tasker. Or create an IFTTT rule to maybe send you an e-mail when connected to said WiFi?
    Golfdriver97 likes this.
    03-10-2014 09:36 AM
  4. cheapskate12's Avatar
    Thanks for the reply, guys. As my handle might indicate I should add I'm looking for a free solution! I will look into the IFTTT solution but any further insight from others would also be greatly appreciated.
    03-10-2014 09:58 AM
  5. SpookDroid's Avatar
    Microsoft's On(x) is free and does share some features with Tasker and IFTTT.
    03-10-2014 12:08 PM
  6. cheapskate12's Avatar
    It's amazing there's no free apps that can do this simple task.
    I briefly looked into IFTTT but looks like it's iOS centric. Even so I'm not sure how to go about giving it a trigger for when a specific wifi network is connected or if it's possible.
    03-10-2014 05:56 PM
  7. Not Bob's Avatar
    03-11-2014 11:42 PM
  8. cheapskate12's Avatar
    Hi Bob, thanks for the response but what you posted is just a widget that displays the connected network and does not address my issue of giving notification when connecting to a specific network.
    03-12-2014 08:23 AM
  9. Not Bob's Avatar
    What type of notification are you looking for?
    03-12-2014 10:37 AM
  10. cheapskate12's Avatar
    An Android notification.
    03-12-2014 10:45 AM
  11. cheapskate12's Avatar
    Bumping this one last time in case anyone who may know a solution missed it.
    03-13-2014 10:19 AM
  12. TheMacs's Avatar
    Not aware of a free solution. Tasker should do it, but it does cost.
    FWIW, while the price may be a bit high, the app can do just about anything. You're only real limits are your imagination, and ability to figure out how to do what you want. The app's wiki, and xda page can help with the second part. Check out some of the cool stuff folks do with it on youtube.
    Good luck!
    03-13-2014 12:11 PM
  1. [App mod] milk music on any device.
    By prepaidguy9081 in forum Android Sideload Wonder Machine
    Last Post: 05-19-2015, 03:19 PM
  2. Verizon Note 3: Wifi connection unstable
    By ansa82 in forum Verizon Samsung Galaxy Note 3
    Last Post: 08-15-2014, 07:33 AM
  3. Stock apps
    By grunt0300 in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 03-17-2014, 10:28 AM
  4. Real Racing 3 graphics app.
    By mothman1270 in forum Samsung Galaxy Note 3
    Last Post: 03-11-2014, 04:21 AM
  5. Replies: 2
    Last Post: 03-10-2014, 04:14 PM
