Results 1 to 3 of 3
    Default I need help installing cyanogenmod on my Verizon Galaxy S4
    Hello. I have a rooted Verizon galaxy S4 i595 (Snapdragon). I tried to install cyanogenmod 10.2.1 but was unable despite the multiple tutorials I looked at. None seemed to work. None of the tutorials explained how to install the ROM manager. It resetted Touchwiz to factory settings. Here is what I have done.
    1. I downloaded the ROM from the cyanogenmod website
    2. I installed Clockworkmod
    4. I copied the ROM into my SD card
    5. I told it to completely wipe my phone.
    6. I went to the menu to install from an external card and found the .zip and told it to install.
    It got a few errors relating to verifying a signature and just brought me to factory settings touchwiz. It also said "No Command". It is still rooted.
    7. Then i tried a "touchwin", but I think that the clockworkmod would not allow it to do anything.
    What did I do wrong? What should I do? Do I need to remove clockwork recovery? Thank you.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,731 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: I need help installing cyanogenmod on my Verizon Galaxy S4
    Try installing TWRP and see if you can get it to work.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Are you on Android 4.3 or an earlier version? If you're on 4.3, you can't install any more ROMs.
  1. Droid X: Help sbf
    By Marc Jenkins1 in forum Motorola Droid X
    Last Post: 03-21-2014, 02:07 PM
  2. Verizon Moto X 16gb - Shattered Screen - $120 obo
    By roadrat in forum Marketplace Archive
    Last Post: 03-16-2014, 09:15 PM
  3. Please Help, Unlocked S2 Wont Connect to Wifi!
    By Ally Bell in forum Samsung Galaxy S II
    Last Post: 03-11-2014, 01:38 AM
  4. disable album art on lock screen (KitKat 4.4.2) ??
    By geekymcfly in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 03-11-2014, 12:06 AM
  5. Samsung Galaxy s2 lcd cracked but not glass...can it be fixed?
    By MissMegan223 in forum Samsung Galaxy S II
    Last Post: 03-10-2014, 11:30 PM
