Results 1 to 4 of 4
    Default Adobe flash !
    Is there still away to get and run adobe flash on android ? I've seen downloads and have downloaded but it never seemed to work. Any one know ?
  2. #2
    Default Re: Adobe flash !
    Flash is usable on my TF-101 with a custom 4.4.2 ROM and using Dolphin Browser.
    I found the adobe 4.0 android flash player download but not sure if it actually runs.
    Thanks for the reply.
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    It actually works, but not all browsers support it. Dolphin and Next do. (Put the browser in Desktop mode if you want to see Flash working. Most mobile sites don't use Flash because Android no longer officially supports it. If "m." is at the beginning of the address in the address bar, you're in mobile mode.)
  1. samsung galaxy s3 samsung logo flashing keeps restarting
    By Angel Angel1 in forum Samsung Galaxy S3
    Last Post: 03-11-2014, 12:31 AM
  2. Replies: 9
    Last Post: 03-10-2014, 09:36 PM
  3. Confirming my flash of CM on my S3
    By Nemesis-X in forum General Help and How To
    Last Post: 03-08-2014, 02:16 PM
  4. Substitute for Adobe Flash Player Plug-in?
    By DL2000820 in forum Samsung Galaxy S4 Active
    Last Post: 03-06-2014, 06:22 PM
  5. Replies: 0
    Last Post: 03-06-2014, 04:39 PM
