Hi guys!
I've installed Android 4.4 on an HP Mini 110 netbook. It' incredible to see that sad machine working so fine without Windows Anyway... the only important problem is that the audio is very very very low, and even looking around on google I hanven't find anything. Could you tell me if is there a solution? It's really sad because everitying work perfectly, the only other (not so important) problem is that the lower part of the app's names are deleted, but someone suggested me to solve it vith another launcher. But the audio problem is really important :'(
