Hi all,
New guy here wondering if anyone else has come across this before.
I was going to put this in the Z1 Compact specific forum, but I figured it might be something that affects other phones so am trying here.
Done a bunch of searching / googling and can't seem to find anyone else with the exact same issue so fingers crossed.
I've got a new Sony Z1 Compact (Great phone by the way!)
I wanted to make use of the magnetic charging port so picked up a dock, a couple of cables and a couple of USB -> Magnetic charger adaptors.
The cables works absolutely fine and charges away very happily.
My dock, and my USB -> Magnetic charger adaptor however both try to put the device into Dock mode.
That in itself works OK, but the problem comes when I want the screen to stay "OFF".
The phone will constantly wake itself up - about once every 90 seconds or so.
The screen comes on, and then times out and goes black again.
It's almost as if someone was pressing the "power" button.
This is obviously very annoying!
Anyone seen this before?
EDIT: As I was writing this I have been trying using the "Daydream" feature to just show a black image.
This also doesn't work... every 90 seconds or so it will return to the home screen before fading back to the daydream screen.
ARGH!!!!!
ARGH!!!!!
