Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By markwalker84
    Default Screen won't stay off when charging via dock.
    Hi all,
    New guy here wondering if anyone else has come across this before.
    I was going to put this in the Z1 Compact specific forum, but I figured it might be something that affects other phones so am trying here.
    Done a bunch of searching / googling and can't seem to find anyone else with the exact same issue so fingers crossed.
    I've got a new Sony Z1 Compact (Great phone by the way!)
    I wanted to make use of the magnetic charging port so picked up a dock, a couple of cables and a couple of USB -> Magnetic charger adaptors.
    The cables works absolutely fine and charges away very happily.
    My dock, and my USB -> Magnetic charger adaptor however both try to put the device into Dock mode.
    That in itself works OK, but the problem comes when I want the screen to stay "OFF".
    The phone will constantly wake itself up - about once every 90 seconds or so.
    The screen comes on, and then times out and goes black again.
    It's almost as if someone was pressing the "power" button.
    This is obviously very annoying!
    Anyone seen this before?
    EDIT: As I was writing this I have been trying using the "Daydream" feature to just show a black image.
    This also doesn't work... every 90 seconds or so it will return to the home screen before fading back to the daydream screen.
    ARGH!!!!!
  2. #2
    Kevin O'Quinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    9,005 Global Posts
    ROM
    Stock
    Default Re: Screen won't stay off when charging via dock.
    Quote Originally Posted by markwalker84 View Post
    Hi all,
    ARGH!!!!!
    If you're using the charging ports on the side I'm not sure you can turn dock mode off. It's designed to work that way.
    Have you went through all of the settings and made sure you don't have an option to turn that off?
    Kevin F.I.M.T.K. O'Quinn Esq.
    Problem solved.
    Feeling pretty stupid about this now... But turns out it was actually a dodgy Mains -> USB converter plug thingy.
    Tried it from a USB port on my laptop and from a different plug and all worked fine.
    Doh!
    Kevin O'Quinn likes this.
  1. Verizon Galaxy S4: My saved video from my gallery won't play!?
    By js13ar in forum Verizon Samsung Galaxy S4
    Last Post: 03-23-2014, 03:12 PM
  2. Orange spot in right hand corner of screen on 2nd phone.
    By mannw1977 in forum Verizon LG G2
    Last Post: 03-23-2014, 10:35 AM
  3. On screen battery drain normal?
    By RionDunn in forum Google Nexus 5
    Last Post: 03-18-2014, 01:20 AM
  4. Replies: 0
    Last Post: 03-12-2014, 09:41 PM
  5. LG G2 charging
    By Norman davenport in forum AT&T LG G2
    Last Post: 03-12-2014, 08:47 PM
