Results 1 to 4 of 4
    Nick Piffle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problem when adding additional Gmail address on Nexus 7
    Hello Everybody !
    My first post so please be kind.
    I have added a second Gmail account to the app on my Nexus 7. I did so by going to Settings > Accounts and adding the new email address there. The email address now appears in the Gmail app and all is working fine.
    My problem however, is that when i pull down the right hand menu on the homescreen (quick settings menu ?), the account that is shown in the top left corner is now the newly added account instead of my original, and main, account and tapping on the image only brings up the contact info for the second account.
    I've looked everywhere and don't seem to be able to change it back to my regular account. I've opened Gmail, Play Store and G+ and made sure they're all set to the main account but it hasn't helped.
    Can anyone advise how I get the drop down (quick settings) menu to display the correct account ?
    Thanks !
    Nick.
  2. #2
    cpaight's Avatar
    Posts
    Global Posts
    698 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Problem when adding additional Gmail address on Nexus 7
    When you go into settings, under the Accounts menu, when you select your Google account does it show both email addresses? There should be some sort of option to select the default account.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi cpaight,
    Yes, I see both accounts there but no way of setting the default. I have tried turning the sync off on the second account but still no luck.
  4. #4
    cpaight's Avatar
    Posts
    Global Posts
    698 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Nick Piffle View Post
    What about going into the settings within the Gmail app? When you click on your email address it gives you the option to set it as the default inbox...that might switch it back.
  1. Nexus 7 (2013) is now $49.99 on Verizon!
    By AldousSnow in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-15-2014, 05:03 PM
  2. nexus 5 or moto x
    By drago1983 in forum General Help and How To
    Last Post: 03-14-2014, 02:48 PM
  3. 4.4 Problems S4 UK
    By jonnymayne1 in forum Android 4.4 KitKat
    Last Post: 03-13-2014, 11:14 AM
  4. A few questions about Nexus 5
    By Ceridan in forum Google Nexus 5
    Last Post: 03-13-2014, 09:57 AM
  5. Problems in my Samsung Galaxy S4's Smart Screen Feature
    By Alextodd1 in forum Samsung Galaxy S4 Active
    Last Post: 03-13-2014, 08:35 AM
