I've deleted my android operating system on Galaxy Fit. HELP!
Alexghe966
So, i've decided to install android 4.2.2. on my samsung galaxy fit.
I searched on youtube and found someone's video. I did exactly what he did, but he skipped something. I needed to install clockworkmode before i tried to install this android.
I still have the 4.2.2. zip file, but it failes to install.
When i enter the download mode(home button+lock+volume down), it freezes on that yellow triangle and an android shoveling. Help, please :(!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Open the zip file. See if you have 4 filles in it, a pit file and 3 md5 files.
If you do, you can try installing those files using Odin, which is the proper way to flash a Samsung.
If not, you can look on Sammobile Firmwares/ (use s5670 as the phone's number) to see if they have the firmware for your country/carrier.
tress
