Results 1 to 2 of 2
    Alexghe966's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I've deleted my android operating system on Galaxy Fit. HELP!
    So, i've decided to install android 4.2.2. on my samsung galaxy fit.
    I searched on youtube and found someone's video. I did exactly what he did, but he skipped something. I needed to install clockworkmode before i tried to install this android.
    I still have the 4.2.2. zip file, but it failes to install.
    When i enter the download mode(home button+lock+volume down), it freezes on that yellow triangle and an android shoveling. Help, please !
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Default Re: I've deleted my android operating system on Galaxy Fit. HELP!
    Open the zip file. See if you have 4 filles in it, a pit file and 3 md5 files.
    If you do, you can try installing those files using Odin, which is the proper way to flash a Samsung.
    If not, you can look on Sammobile Firmwares/ (use s5670 as the phone's number) to see if they have the firmware for your country/carrier.
  1. LG G2 stuck on TWRP menu bootloop
    By Rahul Puri4 in forum LG G2
    Last Post: 07-11-2016, 09:29 AM
  2. Reading a Book on Nexus 7
    By gerryp123 in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-03-2014, 12:56 PM
  3. Anyone Interested in Unbricking my Nexus 7 (2012)??
    By Grant Ziebell in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-24-2014, 06:08 PM
  4. I`ve come to the conclusion that you are better off with the Note 10.1 2014
    By angry english in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 03-13-2014, 06:19 PM
  5. HELP Apps question
    By jfb42 in forum HTC EVO 4G LTE
    Last Post: 03-13-2014, 02:10 PM
