1. Blazalin's Avatar
    These are my battery stats. Usually when i'm idle without wifi or data on, i get about 1% drained every hour. With screen on without those on about 1% every 20-40min. With wifi on, i lose 1% every 2-4 minutes. I don't use data at all and only use wifi. Can you guys help me with this problem? I'm rooted with cm11 4.4.2 with their kernal. sgh-t999.
    Thanks!
    Battery Normal? (GSAM)-screenshot_2014-03-12-23-52-26.pngBattery Normal? (GSAM)-screenshot_2014-03-12-23-52-33.pngBattery Normal? (GSAM)-screenshot_2014-03-12-23-52-43.pngBattery Normal? (GSAM)-screenshot_2014-03-12-23-52-48.pngBattery Normal? (GSAM)-screenshot_2014-03-12-23-53-14.pngBattery Normal? (GSAM)-screenshot_2014-03-12-23-53-18.png
    03-13-2014 11:47 PM
  2. Golfdriver97's Avatar
    The cause is most likely your mobile signal. Cell phones will kill themselves to maintain any kind of signal no matter how weak.
    srkmagnus and dpham00 like this.
    03-14-2014 08:50 AM
  3. srkmagnus's Avatar
    Also, make sure you don't have the screen brightness to Full or Automatic. Keep it conservative - I have mine (Nexus 5) to less than 50% and find it acceptable. Also, make sure you set WiFi to always on during sleep (settings > wifi > menu > advanced).
    For more battery saving tips take a look at the guide B. Diddy put together, it's worth a look and will help you extend the life of your battery: http://forums.androidcentral.com/amb...ving-tips.html
    Golfdriver97 likes this.
    03-14-2014 11:32 AM
  4. realstreets's Avatar
    To troubleshoot. I would unplug the internet from your router. Connect and see if your battery still dies. If so then it's a connection issue with your router and phone. If not then it could be an issue with a data-using app.
    03-15-2014 12:22 PM
  5. dpham00's Avatar
    How strong is the wifi signal?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-15-2014 01:48 PM
  6. Blazalin's Avatar
    Well it doesn't matter if i have full wifi bars or 1. either way, it drains. But i'm going to try unplugging my router see if that helps.
    EDIT: it didn't do anything to help. But, i was wondering what these settings do?
    03-15-2014 09:04 PM
  1. Replies: 13
    Last Post: 08-20-2016, 11:28 AM
  2. On screen battery drain normal?
    By RionDunn in forum Google Nexus 5
    Last Post: 09-25-2014, 11:34 AM
  3. Replies: 22
    Last Post: 09-23-2014, 04:35 PM
  4. HTC One: Post your battery stats here!
    By dandrew68 in forum HTC One M7
    Last Post: 03-15-2014, 11:14 AM
  5. Note pro 12.2 battery issues
    By dentalexel in forum Samsung Galaxy Note Pro 12.2
    Last Post: 03-14-2014, 08:11 AM
