1. Blair Dewar's Avatar
    Hi there Guys
    Im looking for a way to leave my mobile data on, BUT only giving access to apps that i choose. For example, Mobile data should be on, but i want ONLY Whatsapp or BBM to connect to the mobile network. Is there an app that lets you do this? or settings somewhere. For the life of me, i cant figure it out.
    Samsung Galaxy s4 is the phone
    03-14-2014 05:18 AM
  2. srkmagnus's Avatar
    Hi there Guys
    That's a pretty strict requirement. You can see if Tasker (app) allows you to do that. But what specifically are you trying to accomplish? I mean, other than not letting other apps access data? Is it battery consumption? Data? Because most apps that access data can be set to not sync automatically or retrieve data unless you tell it to.
    Blair Dewar likes this.
    03-14-2014 11:28 AM
  3. Blair Dewar's Avatar
    Its so save on data consumption, your reply was really helpful. Thank you
    03-25-2014 03:36 PM
  1. T-Mobile Conway, SC.
    By net62957 in forum T-Mobile
    Last Post: 03-16-2014, 11:27 PM
  2. Note 3: Battery averaging out to about 4 and a half hours?
    By tripleh3lix in forum Samsung Galaxy Note 3
    Last Post: 03-15-2014, 06:42 PM
  3. Climbing Dragon - Climb to the top! Dodge the spikes!
    By davidsolar41 in forum Android Games
    Last Post: 03-14-2014, 08:37 AM
  4. 3d ninja runner android app
    By mayankhanda in forum General News & Discussion
    Last Post: 03-14-2014, 05:18 AM
