03-14-2014 03:00 PM
  1. katie54321's Avatar
    hi i transferred my camera photos to my sd card and cant find them anywhere
    how i did this
    my files
    images
    device storage
    camera
    select all
    created a new folder in sd card called new sd photos
    and moved them to there
    and now i cant find folder or photos
    03-14-2014 07:47 AM
  2. srkmagnus's Avatar
    how i did this
    my files
    images
    device storage
    camera
    select all
    Check to make sure that you actually saved the pictures onto the external sd card and not the internal sd card by accident. Also, use a file manager to search the directory you saved the photos in just to make sure the images are there. If there, then make sure the photo gallery/viewer app you are using can see that same directory.
    Golfdriver97 and B. Diddy like this.
    03-14-2014 11:51 AM
  3. Golfdriver97's Avatar
    Welcome to the forums. I agree with magnus. Most of the time, files are saved by default to the internal memory.
    03-14-2014 11:55 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Yes, agree with above. Remember that with Android, the Internal Storage is considered by the system to be an "internal SD card," even though it's not removable. If you look at your directories with a file manager, you'll see "sdcard0" (which is the Internal Storage) and "sdcard1" (which is the External SD card).
    03-14-2014 12:45 PM
  5. Ealevenish's Avatar
    +1
    03-14-2014 01:11 PM
  6. katie54321's Avatar
    thanks for the info but i checked all the files on my sd card and device storage and still cant find the photos is it possible that when i moved them they got deleted
    03-14-2014 02:09 PM
  7. B. Diddy's Avatar
    If you moved the photos to your SD, then remove it from the phone (unmounting first), insert it into your computer, and see if the computer sees the files. Samsung devices tend to have problems with SD card access.
    Incidentally, in the future, I recommend COPYING rather than MOVING photos, since moving will delete them from the source.
    Golfdriver97 likes this.
    03-14-2014 03:00 PM
  1. Samsung Galay S3 charging problem - Samsung won't fix - says its a BER
    By Chrissy Sommer in forum Samsung Galaxy S3
    Last Post: 10-18-2015, 09:46 PM
  2. Restricting Mobile Data Use to selected apps. Please help
    By Blair Dewar in forum General Help and How To
    Last Post: 03-25-2014, 04:36 PM
  3. MoWeather 1.1 for Android is ready on Google Play!!
    By kennywoo123 in forum General News & Discussion
    Last Post: 03-14-2014, 05:33 AM
  4. Any schedule On Off feature on LG G2 ?
    By aaclub in forum LG G2
    Last Post: 03-14-2014, 01:28 AM
