1. ariezgo1's Avatar
    My Samsung Galaxy 7.0 Plus is not holding the charge, everynight I put it to charge, I used less than an hr during the day and then the charge is gone!!! Do I need a new battery, or a firmware update? What's wrong here??
    03-14-2014 02:39 PM
  2. Jay Sacks's Avatar
    My 7 plus was having wake lock issues where some apps were draining the battery while at rest. But, if not that or a rogue app eating your battery, it just might be age. Mine is already two and a half years old on the original battery.
    Sent from my SCH-I605 using Tapatalk
    03-14-2014 02:53 PM
  3. Rukbat's Avatar
    If you conditioned the battery when you got the tab, and recharged it when it went down to about 50%, you can expect anywhere between 18-24 months of use. Any more than that is a gift. Batteries re "consumables" - they're supposed to have to be replaced periodically, iike tires on cars.
    03-14-2014 09:11 PM
  1. Replies: 2
    Last Post: 06-24-2015, 03:08 AM
  2. Not sure where to begin with this post - but I need help.
    By limoman in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-18-2014, 07:49 AM
  3. Not an Android Newbie, But...
    By Lee Payton in forum Introductions
    Last Post: 03-17-2014, 12:08 PM
  4. Replies: 1
    Last Post: 03-14-2014, 02:00 PM
