Results 1 to 4 of 4
    Blazalin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Unknown Wifi Setting?
    Anybody know what these settings do and if they could help with my wifi battery drain problem?
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default
    What device do you have? It just seems like a switch to turn Wi-Fi on or off. If you don't need Wi-Fi on all the time, you might save a little battery by turning it off. Also review this guide: http://forums.androidcentral.com/amb...ving-tips.html
    Edit--sorry, when I wrote the above, I actually didn't see the lower part of that image on the AC app. It'd still help to know what device it is.
    Blazalin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Unknown Wifi Setting?
    Sorry it is the galaxy s3. I just flashed to the newest nightly on cm11. (was on snapshot m3) and i'm still having wifi drainage.
    Quote Originally Posted by B. Diddy View Post
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    If you don't have a solid wifi signal, the phone will keep searching for one, and that eats a lot of battery. If you want wifi turned off after a certain amount of time (the picture says after 2 minutes of non-use), just turn it off manually when you're not using it.
  1. Wifi connected but no Internet
    By trunker1 in forum Motorola Droid Ultra
    Last Post: 12-01-2016, 03:06 PM
  2. Verizon Galaxy Note 2 Wifi Totally Unstable After Update
    By FSchmitthammer in forum Verizon Galaxy Note 2
    Last Post: 11-29-2014, 05:31 PM
  3. Replies: 4
    Last Post: 03-31-2014, 04:33 AM
  4. WiFi notifications force-closing some apps
    By Atranox in forum LG G2
    Last Post: 03-15-2014, 04:29 PM
  5. LG G Pad 8.3: settings menu
    By techie5 in forum LG G Pad 8.3
    Last Post: 03-14-2014, 08:59 PM
