Results 1 to 3 of 3
    newandroiduser416's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Where are my HIDDEN photos?
    I had to do factory reset because I thought that would fix my batter issue (it did not) however, after i restored my data, I can't seem to find my hidden photos. I dont have the option of "show hidden items" in my gallery. I also went to the "my files" folder and opened the ".hide" folder which was empty!
    Any help please????
  2. Best Answer
    Welcome to Android Central! If those photos were stored locally and you did a factory reset without backing them up to the cloud, an external SD card, or to your computer's hard drive, then they were wiped. Not all data is backed up to Google--it has to be data that is directly associated with an app. So the "Automatic Restore" option won't restore photos. Sorry!
  3. #2
    Ealevenish's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default re: Where are my HIDDEN photos?
    Quote Originally Posted by newandroiduser416 View Post
    Any help please????
    Can't help you getting your hidden photos back. Sorry. Hopefully someone else here can.
    But for the next time: never keep your data, secret or not, in only one place. If that one 'place' breaks you're screwed. As you found out.
  4. #3
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
  1. Question for you that were/are on the Edge Plan with VZW
    By brucedbr in forum Samsung Galaxy Note 4
    Last Post: 09-24-2014, 06:37 PM
  2. Why is the max charge on my Note 2 capping out at 72%?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 09-24-2014, 01:35 AM
  3. my andriod google play store
    Last Post: 09-24-2014, 01:30 AM
  4. NEED TO root MY phone
    By Unregistered in forum Ask a Question
    Last Post: 09-23-2014, 07:03 PM
  5. Replies: 0
    Last Post: 09-23-2014, 05:25 PM
