Results 1 to 4 of 4
    Nepherius Alex's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Internal Storage issue
    After rooting my phone and using an app called "GL to SD" I am unable to access internal storage, I even did a factory reset and that didn't fix it. Someone suggested I should reinstall that app and use some restore function however I'm unable to install/download apps unless I have .apk file, so I was wondering if someone has some method to get this apk https://play.google.com/store/apps/d....slf.ListglApp and give it to me.
    Attached Thumbnails Attached Thumbnails Internal Storage issue-2014_03_12_21.49.30.png   Internal Storage issue-2014_03_13_11.35.46.png
  2. Thread Author  Thread Author    #2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Internal Storage issue
    Seriously, no one can help me get that apk, it's a free app ... ?
  3. #3
    Ealevenish's Avatar
    Banned
    Posts
    Global Posts
    154 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Nepherius Alex View Post
    It's also a rooting app.
    People who have not rooted their device probably don't want to, so can't extract that .apk file for you.
    People who have rooted their device don't want to install GL to SD, so can't extract that .apk file for you either.
    Only people who have GL to SD installed can extract the .apk file for you. That's like fishing in the ocean for one particular fish.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Guess so, I just assumed that since installing and extracting the apk would take like 3 minutes total someone could help me. Seems I was wrong.
  1. Samsung Galaxy S4 Keyboard Problem
    By mmostafaei in forum Samsung Galaxy S4
    Last Post: 03-22-2014, 01:47 AM
  2. Problem with my samsung tab
    By kaka1990 in forum Samsung Galaxy Tab 2
    Last Post: 03-17-2014, 03:08 PM
  3. Replies: 4
    Last Post: 03-17-2014, 05:17 AM
  4. Samsung Galaxy S3, earpiece quiet after AT&T software update
    By minicpst in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-16-2014, 04:28 PM
  5. SAMSUNG NOTE 8.0- audio not working while making video- IMP
    By Beni Mahboob in forum Samsung Galaxy Note 8.0
    Last Post: 03-16-2014, 11:21 AM
