1. horizon981's Avatar
    I'm looking for a solution to a problem unique to my case. There are while list and black list apps but I'm sure none of them serves my purpose.
    I'd like to block a few people, but without being rude and without having any notification that they called. What I mean is, they should hear the ring when they call me, but I should get neither vibration nor visual feedback (the usual pick up / hang up screen) nor any notification (irrespective of which mode I'm in). The call should be logged, though, so that I can check it in leisure.
    Is there a solution that doesn't involve having to learn Android development?
    03-17-2014 11:39 PM
  2. ShaggyKids's Avatar
    The app Call Blocker Gold might help you. There are a number of customization I don't remember them all but it may serve your purpose.
    Deb from my Note 3
    03-17-2014 11:41 PM
  3. horizon981's Avatar
    Thanks, I checked out its Play page. It has a mode called "Silence Phone" while blocking, but I'm not sure if it is able to turn off screen as well. It says it "mutes" the incoming call. What does that mean?
    03-17-2014 11:53 PM
  4. ShaggyKids's Avatar
    I have mine set to go to voicemail without any notification in the notification bar. I'm sorry I don't know what mute for this means. You could download the trial version and test it yourself I believe.
    Deb from my Note 3
    03-17-2014 11:59 PM
  5. horizon981's Avatar
    Great! Thanks a lot.
    03-18-2014 12:02 AM
  6. ShaggyKids's Avatar
    Deb from my Note 3
    03-18-2014 12:47 AM
  7. horizon981's Avatar
    With a heavy heart I announce that this did not solve my problem. The Silence mode does just that -- silence. I could still see the screen lighting up.
    03-18-2014 01:34 AM
  8. Ealevenish's Avatar
    You could try 1) not looking at your device..., 2) turning it upside down, 3) sticking it in your pocket, or 4) manipulating notifications with e.g. the free app DynamicNotifications.
    03-18-2014 07:45 AM
  1. My First Game: Jumpy Runner - Non-Stop Fun
    By atifm1 in forum Android Games
    Last Post: 04-08-2015, 07:38 PM
  2. Verizon Galaxy Note 2 Wifi Totally Unstable After Update
    By FSchmitthammer in forum Verizon Galaxy Note 2
    Last Post: 11-29-2014, 04:31 PM
  3. Replies: 3
    Last Post: 03-20-2014, 06:03 PM
  4. non-nexus 7 compatible app actually works?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-13-2014, 09:57 AM
  5. Chromecast: Need ideas non-TV options
    By Still Mostly Harmless in forum Google Chromecast
    Last Post: 03-04-2014, 05:14 PM
