Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By VDub2174
    Default HELP! HTC One aborts
    I unlocked and thought I rooted my 2013 HTC One. However, when I try to update to KitKat (or anything else) I get a message saying installation aborted.
    I tried to RUU the phone back to factory but it doesn't seem to want to do that either.
    Any ideas?
    John
  2. #2
    Default Re: HELP! HTC One aborts
    Check to see if you do indeed have root access. If you do, them updating via OTA isn't the way to go. You can just flash a stock 4.4 ROM.
    Sent from my Anthem filled Note 3
    Golfdriver97 likes this.
    It tried to do an OTA and said installation aborted, then rebooted. Also, I can't seem to find a clean kitkat 4.4 rom to download and sideload to see if that will fix the problem.
    I did try to s-off but it won't let me do that even.
  4. #4
    Which HTC One variation do you have?
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    13,694 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    I'd first check to see if you have in fact unlocked the bootloader. That right there sounds like the problem, and I'm not sure that you can just flash a RUU and be back to complete "stock". There might be a process to relock the bootloader.
    I have the AT&T HTC one
    I have tried to RUU the phone, which it doesn't seem to be able to do that either.
    I can't get S-Off to work either.
    Is there anyway to force a complete reload of everything?
    Thanks
  8. #8
    Let me look that up and/or see if anyone else can help out
    I would appreciate it. I would think there would be a way to basically do a format and reinstall...ah la Windows.
  10. Thread Author  Thread Author    #10
    Anyone? Any ideas?
  1. HTC One headset mic issue
    By Richard Gong in forum HTC One M7
    Last Post: 07-21-2014, 06:34 PM
  2. Help me hack my own phone acer s500
    By justmedana in forum Software Development and Hacking
    Last Post: 04-16-2014, 06:03 AM
  3. App or method to keep photos organized in one folder
    By teamnowak in forum General Help and How To
    Last Post: 03-19-2014, 09:37 AM
  4. Verizon HTC One: Annoying recurring sign-in requests
    By Down with Apple in forum Verizon HTC One
    Last Post: 03-19-2014, 08:30 AM
  5. ProxyDroid setup help - Android 4.3 - Samsung S3
    By meastwood98 in forum General Help and How To
    Last Post: 03-18-2014, 08:42 AM
