Results 1 to 5 of 5
    therealandypandy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default sd encryption...
    If the manufacturer/vendor has chosen not to implement the option, how do you go about encrypting 'the entire file system' on an SD card?
  2. #2
    dctokyo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: sd encryption...
    Quote Originally Posted by therealandypandy View Post
    SSE - Universal Encryption App
    https://play.google.com/store/apps/d...us.android.sse
    or
    Encryption Manager
    https://play.google.com/store/apps/d...one.encmanfull
  3. #3
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    Here is another way. It is a bit more complicated. You can connect the SD Card to a PC and add a truecrypt container inside of it. Everything you put in that container is encrypted with various types of encryption, such as AES-256 encryption You can then use EDS on your phone to open it.
    Truecrypt: http://www.truecrypt.org
    EDS: https://play.google.com/store/apps/d...vworks.edslite
    Sent from my AT&T One X running CodefireX ROM Android Version 4.4.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cheers for the quick reply. Yeah, i wrote to the 'encryption manager' fellow, Hans i think it is, asking whether his app could be used to do this and he said no. I'm wanting to encrypt the 'entire file system' on the card so that it can be accessed in real time by any app on the device that has permission to read/write to the card.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cheers! I imagine that the only people who don't love True Crypt are those that don't about it and the NSA. I didn't know that there was an android app that supported it so, again, cheers,
  1. Does the new SanDisk 128GB micro sd card work on the Galaxy Note2?
    By BlackberryFan2009 in forum General News & Discussion
    Last Post: 04-23-2015, 08:46 AM
  2. Replies: 3
    Last Post: 12-21-2014, 07:49 PM
  3. Kitkat, S3 international and SD cards
    By newandroidguy in forum Samsung Galaxy S3 I9300
    Last Post: 03-24-2014, 06:19 AM
  4. SD Card ejected unexpectedly error!
    By Rohit Bhosale in forum T-Mobile Galaxy S3
    Last Post: 03-18-2014, 11:36 PM
  5. SD Card Won't Mount in Dock
    By crazigee in forum ASUS Transformer Pad Infinity 700
    Last Post: 03-17-2014, 11:52 PM
