1. knight1fox3's Avatar
    The subject line basically says it all. Just curious if anyone else uses this app and has had trouble with it recently. I bought the paid version about 2 months ago and it has worked well up to this point syncing across my GS4, N7, and desktop PC. When a new message would come in, I would see the Firefox add-on bar turn blue. And I could view my messages without ever checking my phone. About a week ago, I no long get push notifications on the PC side. I tried stopping the add-on, removing it completely, then adding it back and re-logging into it. Doesn't seem to help. I checked the DeskSMS settings on my phone and I don't see that anything has changed (there's not a lot to change either). I doubt anything on the PC side changed to make it suddenly stop working.
    So just curious if anyone else has used this app and if you might have run into similar issues. I went with this app over MightyText because MT was missing various messages and not syncing properly with my contacts. And their tech support just quit answering my emails. I tried contacting the dev for DeskSMS but haven't heard anything back as of yet. Any help/suggestions would be greatly appreciated. Thanks in advance.
    03-19-2014 04:42 PM
  2. zedorda's Avatar
    Have you downloaded any new apps recently or upgraded to KitKat?
    03-19-2014 05:30 PM
  3. knight1fox3's Avatar
    Thanks for the response. Nothing aside from just the normal app updates as usual. But I haven't seen any updates for DeskSMS pushed out. I'm running Android 4.3.
    03-19-2014 09:49 PM
  1. Keyboard in notification bar
    By longtime44 in forum Google Nexus 5
    Last Post: 10-05-2016, 05:47 PM
  2. YouTube App not hiding notification bar
    By Lomonocrat in forum Android Apps
    Last Post: 03-24-2014, 06:49 PM
  3. Can't disable messaging app notifications
    By Jason Bourne4 in forum Samsung Galaxy S4
    Last Post: 03-20-2014, 05:53 PM
  4. Sprint Galaxy S4: Security update notification
    By djdonnyk in forum Sprint Samsung Galaxy S4
    Last Post: 03-19-2014, 08:04 PM
  5. Can't figure out stock calendar notifications - need help!
    By Raymond Elliott in forum HTC One M7
    Last Post: 03-18-2014, 12:09 PM
