Results 1 to 3 of 3
    airsoftkiller100's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default HELP my note 2 wont charge correctly...HELP!!!!
    soi hadmy note 2 for a while and its been working wonderfully until one morning i went to get my phone and it didnt charge fully and it stayed at 50% so ijust assumed it was nothing to worry about and during lunch time i pulled out my phone and it died.....WHAT TH HELL!!!!!!, soi thought it was the charger so i got a new one andit still didntwork then i called my provider to get a new battery and it still didnt work, PLEASE HELP. FWI- my phone is about 1 year old and it never got wet but fell out of my pocket abit but no real damage just small cracks and the phone is rooted, when i got the new battery it just came up to 64%,soplease help me......
  2. #2
    Mooncatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: HELP my note 2 wont charge correctly...HELP!!!!
    Are you saying that the batteries never get to a full charge when plugged in, even the new one, or just really slow to charge? And when the old one died like you mentioned, was it a steady decline to zero like normal, or a rapid drop (I.e. going from 35% to zero almost immediately)?
    Normally the first place to look for charging issues is the USB cable because they are so prone to going bad, but you said you got a new charger. Did it have its own new USB cable too? If not and you're using an old one, replacing the cable may fix it if it's just a slow charging issue. Your answers to my first questions could indicate something else going wrong, but the cable would be the first place to check without knowing said answers.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    And if it's not a bad cable, the next likely candidate is the charging port in the phone. They have to take more abuse than they were designed for, so they frequently break a solder joint.
  1. After the new update my Bluetooth sucks
    By Delanoxx99 in forum T-Mobile LG G2
    Last Post: 04-15-2015, 11:22 PM
  2. Replies: 15
    Last Post: 04-06-2014, 04:59 PM
  3. Error Help
    By Don Nichols in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-23-2014, 12:30 AM
  4. Thanks for the help...Sat I migrate to Note 3 forum
    By scratchfwb in forum HTC EVO 4G LTE
    Last Post: 03-21-2014, 10:43 AM
  5. Verizon HTC One: My Google Tasks don't seem to update
    By GMGPR in forum Verizon HTC One
    Last Post: 03-21-2014, 09:47 AM
