1. st9966's Avatar
    I use my cell phone contacts the most and would like to transfer them to my tablet. I don't use my gmail account as my primary email, but I use my home email acct. I have backed up my phone to Verizon cloud, but my tablet doesn't have an option of downloading contacts from the cloud and I get the contacts from FB and gmail. Any ideas?
    03-21-2014 04:15 PM
  2. zedorda's Avatar
    Use Gmail for your contacts even is it is not your main email.
    03-21-2014 04:25 PM
  3. B. Diddy's Avatar
    Try exporting the phone contacts, and then importing them into your Google account. See more details here: [GUIDE] Getting Started with Android (2014), Part III: Managing Contacts
    03-21-2014 05:35 PM
  4. Rukbat's Avatar
    Or look at the contact apps of both the phone and the tab and see if there's a file format they have in common (usually csv). Then export from the phone and import to the tab. Even a vCard file may work, but you may end up having to import one contact at a time - which isn't too bad if you only have a few contacts.
    Another way of doing it is with My Phone Explorer. Connect the phone, copy the contacts and save them (on your computer), then connect the tab and send it the same contacts.
    In the future, use Google for sync - Android phones are designed to sync everything through Google Drive. Create a gmail account even if that's all you're ever going to use it for. (You'll need it to get apps from the Play store.)
    03-21-2014 11:47 PM
  1. Replies: 2
    Last Post: 01-26-2016, 02:21 AM
  2. Replies: 3
    Last Post: 05-14-2014, 05:31 AM
  3. YouTube related to Tapatalk?!
    By THEPRFCT10 in forum Samsung Galaxy S4
    Last Post: 03-25-2014, 11:04 PM
  4. Galaxy S5: Where is Verizon??
    By vladfan in forum Samsung Galaxy S5
    Last Post: 03-25-2014, 07:50 PM
  5. Listening to data traffic
    By i6power in forum Software Development and Hacking
    Last Post: 03-21-2014, 02:00 PM
