Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Jepster
    Jepster's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung Galaxy Centura wifi authentication
    I recently changed routers to a NetGear Nighthawk. Everything else in the house works flawlessly with this, except my Samsung Galaxy phone. I added the new network but the phone will not ask me for the password connected with this router. It has a strong signal but the little lock shows up in the diagram and keeps saying authentication problem. The phone worked fine with my previous router. Help!!
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,120 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung Galaxy Centura wifi authentication
    Welcome to Android Central! Do you know what kind of security protocol the router is using? The ideal one (and most secure) is WPA2-PSK, with AES. If that's what it's set to, then you could try changing things a bit--like changing AES to TKIP.
    Here's a guide with more tips: http://forums.androidcentral.com/amb...-problems.html
    Jepster's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The security protocol is WPA2-PSK - but doesn't say anything about AES. When I set up my old router, and then the phone, the software in the phone asked me for the password, but when I went to set up this new router, it didn't ask for a password and just says it can't authenticate. It sees the signal, but puts a little lock symbol over it, and won't let me in. Frustrating! Post script - Thanks for the troubleshooting guide above. I went in and "forgot" the network I was trying to use and added a new one (which I had done before) - and THIS time it finally asked me for the password. All set! Don't know why it wouldn't ask before. Anyway - we are good to go!Thanks for the help.
    B. Diddy likes this.
  1. Purchased my first Samsung Galaxy Note 2
    By Red_Berry_21 in forum Samsung Galaxy Note 2
    Last Post: 03-24-2014, 11:06 AM
  2. Wifi connection issues
    By Bionic Bobsled in forum Verizon Samsung Galaxy S4
    Last Post: 03-23-2014, 12:06 AM
  3. emails not syncing to galaxy gear
    By ymcewen in forum Samsung Galaxy Note 3
    Last Post: 03-21-2014, 05:10 PM
  4. LG G2 F320L - Wifi not turning on and no mac address
    By Shaker Bin Sulaiman in forum LG G2
    Last Post: 03-21-2014, 04:49 PM
  5. Canadian Samsung Galaxy Tab 3 7.0 Andriod 4.4 Update
    By Dj Prole in forum Android 4.4 KitKat
    Last Post: 03-21-2014, 04:47 PM
