1. jog62003's Avatar
    I just received a job offer and it stated I would supply my personal lg g2 phone. They said they will sync it with their tablet that I will use on the job site. They said they will set up separate accounts for my company email, Skype, calendar,* contacts, files, etc. I'm not sure exactly what they will do. Most important, will they be able to view Skype even if there will be 2 separate accounts. I was thinking I could use the guest mode feature on my LG G2. Please help. Thanks.
    03-22-2014 01:04 AM
  2. Ealevenish's Avatar
    Switch SIM cards from 9 to 5.
    03-22-2014 08:49 AM
  3. jog62003's Avatar
    I don't know too much about Androids but what would that do? Can you explain in more detail?
    03-22-2014 12:20 PM
  4. srkmagnus's Avatar
    Sim cards would just switch the number and data services. It wouldn't change anything on the device.
    I would suggest doing the guest mode on your device for work to keep things separate. I don't use that type of feature, so not sure how it will affect your personal messages or calls.
    03-22-2014 01:38 PM
  1. Using non-Verizon SIM card problem
    By Gecko123 in forum Verizon LG G2
    Last Post: 03-08-2017, 01:38 PM
  2. Gear 2 Neo: My Best Buy has them on display and they are sweet!!
    By elvis1935 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-03-2014, 11:07 PM
  3. Can anyone one confirm if this actually works with this particular model of phone?
    By pawprints86 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-22-2014, 12:09 AM
  4. How do i use my freshly rooted nexus 10 as a USB mass Storage device for the xbox 360?
    By Justin McIntyre in forum Nexus 10 Rooting, ROMs, & Hacks
    Last Post: 03-22-2014, 12:07 AM
  5. Replies: 0
    Last Post: 03-21-2014, 11:13 PM
