1. felix001's Avatar
    hope this is the right place to post - if not please move it to the relevant place
    I have just bought an Android Smart TV Box (to replace my AC Ryan media box which gave up the ghost a few days ago) and it mostly works fine - it is connected to my tv via hdmi and the box is hard wired to my router - so it is the standard connection setup. I have two usb hard drives connected to it.
    I obviously want to drag and drop media files from my phone (android) or my laptop (Windows7) to the connected hard drives
    I use ES Explorer app on my phone and Windows explorer but using either version I cannot see the Android box wirelessly - if i do a scan using es explorer it finds the laptop straight away and i can drag and drop but it just will not find the android box at all. However if i go onto the Android box and into the es explorer app and do a scan it picks up the laptop and i can drag and drop a file onto the laptop. So the wireless is sort of working as opposed to not at all. But just seems odd that i cant see it at all - i cant even ping it from the laptop. I have been through all the settings but no luck. If anyone has any ideas how to fix this it would be much appreciated
    thanks
    03-22-2014 12:47 PM
  2. wizzrah's Avatar
    thanks
    Hello! Try this. Download Wifi File Transfer on your Android Box:
    1. Once Downloaded, open the app.
    2. It will display a start button. Click it, and it will display an address (Example: 10.0.0.7:1234)
    3. Visit this address on your computer and you should see the contents of the android box.
    You can then upload stuff to your android box.
    03-22-2014 02:27 PM
  3. felix001's Avatar
    thanks very much. that works..but I'm surprised I can't just use something like Es explorer to copy files back and forth from one Android device to another using drag and drop-as I did from my phone to my AC Ryan media box that I had before. this seems to be a very clumsy way to transfer files..plus I can't see the hard drives attached to the Android box, so I have to copy to the internal memory first, then move to the external drive?
    03-22-2014 06:02 PM
  4. wizzrah's Avatar
    You can do this with ES File Explorer, but I don't think you can upload, you can only see files. I think it's the net manager option. I think you might have to move files onto the box and then the hard drive. Does your box have root access?
    Sent from my AT&T One X running CodefireX ROM Android Version 4.4.
    03-22-2014 06:38 PM
  5. felix001's Avatar
    I have looked at the net manager option but that gives me nothing, just shows my wireless connection details. the box isn't rooted but I can look to do that. I don't know how but I'm sure I can find the instructions on here. if I do root it, will that give me the option to drag and drop files to it ?
    the current way of copying to the box and then to the hard drives would be okay, but the onboard storage is only 1GB so any films I have over that size I wouldn't be able to transfer
    03-23-2014 02:42 AM
  6. wizzrah's Avatar
    I'm going to experiment with my phone for a bit. I'll get back to you in a bit and tell you if I find anything.
    In the mean time, I think you would have to connect the hard drives directly to the PC and transfer the files there.
    03-23-2014 10:23 AM
  7. felix001's Avatar
    hi, I don't know if you had any luck but I haven't. seems that you can't see the external drives remotely
    03-26-2014 09:54 AM
  8. wizzrah's Avatar
    I'm experimenting with different things still. I'm going to connect a USB stick to my phone to mimic an external hard drive. I'll try to see if I can read it.
    03-28-2014 02:44 PM
  9. Eddie Pritchard's Avatar
    Old thread, but for anyone else looking this up, I believe the issue is that the wifi on Android boxes is very weak, due to them using a cheap receiver to keep costs down. This is also why Miracast/Mirroring wont work too.
    11-14-2015 09:22 AM
  1. Android Device Manage only works on WiFi
    By richlaustx in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-22-2014, 02:36 PM
  2. Replies: 12
    Last Post: 03-25-2014, 07:53 PM
  3. Calendar apps that sync directly to my google calendar?
    By MrDoh in forum Verizon Galaxy S III
    Last Post: 03-25-2014, 06:37 PM
  4. [iOS][Android][FREE] Crazy Meme Shooter is out!
    By Tonitrus in forum Android Games
    Last Post: 03-25-2014, 05:26 PM
  5. android system sync disabled
    By gumtreebuyer6 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-22-2014, 12:35 PM
