Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Gevio WhiteWizard
    Default odin 3.09 problem
    Hello , i downloaded osin to my pc , i connected my tablet in it and i installed a recovery , but when i tape volume up + home key + power key at boot it loads the default recocery ...
    Why should that happen ??
    UJ95x likes this.
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,691 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: odin 3.09 problem
    Quote Originally Posted by Gevio WhiteWizard View Post
    What recovery are you using? It should load the custom recovery that you flashed.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Unless the flash failed.
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    What recovery did you install? ClockworkMod looks very similar to the stock recovery, so that might be what you're seeing
    Sent from my Galaxy S4 running SlimKat 4.4.2
    I installed CWM but i didnt know it want root ...
    Now when i go to software update it shows me that my device has been modified ..............
    I am going to root my device now and will this error be gone ??
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    I'm pretty sure root comes before recovery. That's how I did it at least.
    Your device will show as modified regardless of whether or not you have root. Depending on what Android version you are on, you might be able to reset the flash counter so that it shows as not modified
    You mean that i must have root to add a custom recovery ? How to get software update again ?
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    That's how it worked for me (also a GS4)
    To flash back to stock, download a stock firmware on sammobile.com and flash in Odin
    I will root my tab 3 , can i install android 4.4 kitkat to it ???
  10. #10
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    If you find a 4.4 Kit Kat ROM then yes
  1. Using non-Verizon SIM card problem
    By Gecko123 in forum Verizon LG G2
    Last Post: 01-03-2016, 01:49 AM
  2. Sprint Note 3: Facebook problems with KitKat update
    By Ntchwaidumela in forum Sprint Samsung Galaxy Note 3
    Last Post: 03-26-2014, 04:47 PM
  3. Note 3: Problem with Firefox after KitKat download
    By Spartiatis in forum Samsung Galaxy Note 3
    Last Post: 03-25-2014, 05:03 AM
  4. Please help with my lock screen problem.
    By onewordepic in forum HTC One M7
    Last Post: 03-23-2014, 03:32 PM
  5. Problem with s-pen
    By Kiwy10 in forum Samsung Galaxy Note
    Last Post: 03-21-2014, 02:41 PM
