Results 1 to 4 of 4
    Default Transferring text messages from Nokia Lumia 820 to Samsung Note 2. Is this possible?
    Hello All,
    Long time reader, first time poster.
    Is it even possible to transfer text messages from Nokia Lumia 820 (So Windows 8) to a Samsung Note 2 (Amdroid)?
    Any advice/hints/tips would be greatly appreciated as I dont want to lose years worth of texts.
    Gareth
  2. #2
    Default Re: Transferring text messages from Nokia Lumia 820 to Samsung Note 2. Is this possible?
    Hey,
    there is this app called "Transfer my Data" on your phone, if there isn't try looking it up on the Windows Store. Just run that particular app and follow the on screen instructions. It will solve your problem with ease
    Many thanks for your prompt response. That only works if I'm transferring to the Windows Phone, I'm trying to transfer from the Windows Phone to the note. Any further help greatly appreciated
  4. #4
    Quote Originally Posted by Fraseniuc Lucian View Post
    That's from a Symbian device to Android, not Windows Phone to Android.
    Your best option would be to find a Windows Phone app that can export your texts to XML and then import that on your new phone. I am not familiar enough with Windows Phone to know of an app that will do that for you though.
  1. App to lock tablet on a particular application?
    By sethgoldstein in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-06-2016, 01:06 PM
  2. "Pen only" function in S-Note also in PDF editor?
    By andre_xs in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 11-28-2014, 10:52 AM
  3. Replies: 17
    Last Post: 05-05-2014, 08:09 PM
  4. Unrooting from CM 11 after a previous stock 4.3 OTA update - NAND Write Fail!!
    By mr_legolas in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 04-19-2014, 03:22 PM
  5. Did anyone switch to Nexus 5 from the Galaxy S3?
    By Crispy in forum Google Nexus 5
    Last Post: 04-03-2014, 10:56 AM
