Results 1 to 10 of 10
    pawprints86's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I have a question regarding rooting
    I know what it means after some research.
    But what my research did not answer is - if i tried rooting and messed something up, is it still possible to do a reset back to factory settings?
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    Default Re: I have a question regarding rooting.
    Quote Originally Posted by pawprints86 View Post
    It depends on your device. What device do you have?
  3. #3
    SactoKingsFan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you mess up the phone you can usually get back to stock as long as you have appropriate file for the stock software. Methods for flashing back to stock differ for various phones.
    Sent from my LG-G2 running Carbon 4.4.2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wizzrah View Post
    Well, i dont have it yet but ive been wanting to get the samsung galaxy ace q/appeal. Considering buying it and trying any modding before adding any of my own personal touches to the phone.
  5. #5
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    Before you decide to do some modifications to your phone, do you have a definite reason as to why you want to root? Rooting will void your warranty.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can only get it on ebay/amazon so it wont have a warranty anyway, so im not too worried about that part.
    The reason I would want to root is because it runs 2.3.6 out of the box and i keep hearing people say that absolutely no apps will download, and that if they do now, they will not in the very near future. But I really like the model of the phone itself. So I was thinking that rooting could mean the best of both worlds - having the handset I really want with an up to date operating system.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wizzrah, if i do get this phone and decide to root it. Where do i go from there to find an updated OS to use on it? Ive had trouble finding that information, for any phone let alone the one i want.
  8. #8
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    You probably have to root, and then go to a place like XDA for ROMs.
    Sent from my AT&T One X running CodefireX ROM Android Version 4.4.
  9. #9
    Rukbat's Avatar
    Posts
    Global Posts
    22,840 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Rooting will not let an app written for Android 3+ to run on a phone running Android 2.3.6, it will only allow apps written to run on 2.3.6 or higher that beed root access to run.
    The only way to get current apps to run would be to flash a Jellybean ROM to it and there are 2 problems with that:
    1) You probably won't find any
    because
    2) The phone's hardware won't support it.
    Even if you could modify a JB ROM yourself to run on the phone, the phone has only 4GB of internal storage (the only kind that matters as far as running apps is concerned), and that's not going to be enough to run the ROM and more than a few small apps. Even 16GB is considered tight these days. Current phones are made with 32GB, and there are rumors of 64GB phones coming down the pike soon. A 4GB phone, running an almost 4GB ROM, isn't going to be something you'll be happy with.
  10. Thread Author  Thread Author    #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Rukbat View Post
    because
    I saw on youtube someone running jellybean on a regular samsung galaxy ace... so im sure its possible.
    But my question now is, could i use an SD card to serve as more gigabytes available for rom usage? Those arent all that expensive these days either... in fact i have an 8gig one just sitting around right now because of a 2 for 1 sale.
    Some thing to keep in mind too is that I wouldnt want it to make my coffee for me and start my car and all of that jazz. I would run a few games and probably facebook. It wouldnt be app heavy at all.
  1. Replies: 17
    Last Post: 05-05-2014, 08:09 PM
  2. Rooting and root access
    By Sax_Derp in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-26-2014, 10:40 AM
  3. Several questions for a newbie
    By jeeeps in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-23-2014, 05:16 PM
  4. Advice for Root Please?
    By FamilyMedic1 in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 03-23-2014, 12:54 PM
  5. Does the 10.1 2014 have a recycle bin I can access?
    By DestinyAngel in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-23-2014, 11:22 AM
