Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By Vsweety
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Phone display to tv?
    I saw the details about chromecast that it doesnt support FULL display transfer into tv, only certain applications work.
    Im using nexus 5. Which device can display everything from my phone to tv, including scrolls, main menu, everything.
  2. #2
    SpookDroid's Avatar
    Posts
    Global Posts
    11,697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Phone display to tv?
    Any phone with Miracast (or AllShare/Samsung Link for Samsung phones) support is able to 'mirror' your phone to your TV. However, not all TV's are capable of this. Same thing with Chromecast; unless you get an app that mirrors your phone as a video feed, you're restricted to media sharing and streaming from apps that support it.
    What's your phone model? Do you have a SmartTV (if so, what model) or are you only using Chromecast?
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SpookDroid View Post
    Im using Nexus 5 unlocked version from Google Play. TV is Samsung EH5300
  4. #4
    SpookDroid's Avatar
    Posts
    Global Posts
    11,697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, it SHOULD work with a Samsung SmartTV... I've only tried it with my Note 3, so maybe it's 'easier' because both are Samsung products, but the process should be the same:
    1) On the TV, go to the Screen Mirroring channel/input. It'll start 'looking' for connectable devices.
    2) On the phone, activate the Screen Mirroring option. I'm not sure how it's called in your Nexus but there should be a mirroring option or Miracast something available.
    3) Wait for the two to pair.
    4) Enjoy.
    5) Run for the charger; screen mirroring drains your battery pretty quickly.
    Oh, and remember, both TV and phone need to be in the same network or they won't be able to 'find' each other.
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    so tv and phone must be connected to same router?
    i dont think EH5300 have wifi built in.
  6. #6
    SpookDroid's Avatar
    Posts
    Global Posts
    11,697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well according to specs, no, it doesn't support WiFi but it does have an Ethernet port available so you could connect that to the router and the phone to the same router's WiFi and that should do it.
    Sent from my SM-P600 using AC Forums mobile app
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    that's also an option.
    just to confirm, i don't need to buy any device, tv's built in software and my phone's built in software will do everything, correct?
  8. #8
    SpookDroid's Avatar
    Posts
    Global Posts
    11,697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you can get them to 'see' each other on the same network, yeah, you shouldn't need a Chromecast to see 'stuff' in your screen. You could try 'small' things first, like using Miracast to display your pictures or videos on the TV, and then try to use the screen mirroring feature.
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    what about phone to laptop?
  10. #10
    SpookDroid's Avatar
    Posts
    Global Posts
    11,697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think you can stream media from your phone to your laptop using Samsung's software (S-Link I think it's called, don't really remember, they've changed the name so many times already) but I don't know of an easy or straight-forward way to mirror your phone's screen on the computer.
    EDIT: I did find this video on YouTube... MAAAAAYBE it'll help. Haven't really tried it myself.
  11. #11
    Vsweety's Avatar
    Banned
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can with the Teamviewer app.
  12. #12
    SpookDroid's Avatar
    Posts
    Global Posts
    11,697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does that work both ways? I thought you could only mirror the PC on the phone or tablet... Hummm... Good to know
  13. #13
    Vsweety's Avatar
    Banned
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes. Wireless. So remotely too. There is a slight lag, though, dependent on the speed of your connection.
    You can for instance operate your computer at home, or at work, remotely from your phone or tablet while you are 'in the field'. Or you can act as a helpdesk for your friends' and relatives' devices where ever you are. Or stream a presentation for display elsewhere, while its file doesn't actually get downloaded to that remote device.
    SpookDroid likes this.
  14. Thread Author  Thread Author    #14
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this didnt work, have u tried it?
  15. #15
    SpookDroid's Avatar
    Posts
    Global Posts
    11,697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I haven't tried it but someone else pointed out that you could do that with TeamViewer, and that sound like a much more simple way to do it
  16. Thread Author  Thread Author    #16
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ok then, will do it in free time (using teamviewer).
  17. #17
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    You can also do "phone screen and input on laptop" with MyPhoneExplorer (free in Play). Screen, keyboard, mouse.
    You can also put a VNC server on the phone and run a VNC viewer on the laptop. (Since you're on the same network, I assume, you don't need Team Viewer's ability to jump routers.)
  18. Thread Author  Thread Author    #18
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this is weird, whenever i connect my phone to the laptop, im receiving this window (look screenshot below), it wont show the phone window.
  19. #19
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MyPhoneExplorer and VNC will. MyPhoneExplorer will do other things to - it's Android-specific so it does contacts, texts, etc.. But a VNC connection is just a remote connection to another computer - you can control the remote computer from the local one. You see the entire screen, use the mouse and keyboard, some of them even do audio. (Trying to do video, even on a local wifi connection, may not work great, though.)
  20. Thread Author  Thread Author    #20
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I dont want to control my phone or my laptop from any device. I just want to make the screen of my phone big by displaying it into my laptop.
    Btw, i installed vnc viewer, it installed bing toolbar and changed my homepage. Not going to install it ever again.
  21. Thread Author  Thread Author    #21
    hell911's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is great, i can watch vids and see pics from my phone to tv using the playto samsung app and allcast app. Now i need to find a way to mirror games.
  22. #22
    Malcho's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am using Flipps. It's a great app. The streaming from my phone (or tablet) is immediate. The app just takes control over the TV. I can watch tv shows, news, sports, etc.
  23. #23
    Concept96Ltd's Avatar
    Posts
    Global Posts
    11 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Chromecast will do full screen mirroring if you have a supported device.
  1. Note 3: how to stop incoming texts from pausing music?
    By sasfood in forum Samsung Galaxy Note 3
    Last Post: 07-31-2016, 01:29 PM
  2. How's your phone holding up?
    By jpdaballa in forum Sprint LG G2
    Last Post: 03-31-2014, 11:11 AM
  3. How to save image from the browser in moto x?
    By seetha lakshmi in forum Moto X (2013)
    Last Post: 03-24-2014, 11:58 AM
  4. Back button not working and phone stopping
    By Melanie Holditch in forum General News & Discussion
    Last Post: 03-24-2014, 11:07 AM
