1. Rexkh's Avatar
    Hi
    My question is, unlock bootloader mean unlock network(Sim or Carrier)?
    03-25-2014 06:28 PM
  2. Golfdriver97's Avatar
    Hi
    No. Unlocking the bootloader is unlocking part of the OS, typically needed for rooting/flashing ROMs.
  3. Golfdriver97's Avatar
    Hi
    03-25-2014 06:32 PM
  4. UJ95x's Avatar
    Hi
    Nope. Unlocking bootloader means you can flash custom recoveries and the like, but not use a different carrier.
    Sent from my Galaxy S4 running SlimKat 4.4.2
    03-25-2014 06:32 PM
  5. Rexkh's Avatar
    I used to have an iPhone. To unlock carrier, I have to jailbreak(root) and install a app to unlock. Is an android device the same way?
    03-25-2014 06:43 PM
  6. dpham00's Avatar
    An unlocked bootloader can help you unlock the sim though, depending on the situation
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-25-2014 06:44 PM
  7. Rexkh's Avatar
    What kind of situation that can unlock sim? Example of LG Optimus G E973?
    03-25-2014 09:27 PM
  8. Rukbat's Avatar
    You get the unlock code from the carrier (or buy it from one of many places that advertise on eBay). When you put in the "foreign" SIM it'll ask for the unlock code. Put it in and the phone will be SIM-unlocked. It doesn't have to be rooted (the Android equivalent of jailbreaking).
    03-25-2014 11:01 PM
  9. Rexkh's Avatar
    Is there any apps that will unlock network just like ultrasn0w for iPhone? And now, I have another problem. I'm on custom rom and it stop asking to enter unlock code. I don't know how to enter the code.
    03-25-2014 11:26 PM
  10. dpham00's Avatar
    Did you put in a sim from another carrier?
    03-26-2014 12:27 AM
  11. Rexkh's Avatar
    Yes, I do. However, now I want to restore Stock Firmware from LG in kdz format but I can't, because I have CWM Recovery Menu installed and I can't get back to original Recovery Mode. What should I do?
    03-26-2014 06:58 PM
  12. Melanie Poole's Avatar
    Hi
    03-27-2014 05:19 AM
  1. Pughop - Can you unlock all the skins?
    By Bitrogue in forum Android Apps
    Last Post: 07-03-2014, 11:45 PM
  2. Replies: 9
    Last Post: 04-22-2014, 11:21 PM
  3. Verizon HTC One (M8) GSM Unlocked?
    By nickmiller71 in forum HTC One M8
    Last Post: 03-25-2014, 09:29 PM
  4. HTC One (M8): Buying unlocked?
    By fdzye in forum HTC One M8
    Last Post: 03-25-2014, 01:42 PM
  5. Got unlock and S-OFF, but cannot get any cell service with any ROM
    By firebirdude in forum Verizon Droid Incredible 4G
    Last Post: 03-25-2014, 10:11 AM
