1. Shiv Rulz's Avatar
    My phone suddenly switches off and battery goes down from 70 - 80 % to 2 - 3%.
    this usually happens when mobile network is switched on.
    is there a problem with battery or some app is causing this??
    Attached Thumbnails s3 mini battery draining problem-screenshot_2014-03-26-21-19-40.png   s3 mini battery draining problem-screenshot_2014-03-14-17-37-55.png   s3 mini battery draining problem-screenshot_2014-03-09-20-51-11.png   s3 mini battery draining problem-screenshot_2014-03-24-23-58-23.png
    03-26-2014 11:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery could be failing. Take it out, place it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle and therefore going bad. Try a new battery.
    03-26-2014 01:04 PM
  1. which app use more battery
    By mfaridi in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-27-2014, 12:00 PM
  2. Note 3: Is my overnight battery drain normal?
    By jaystaygrindin in forum Samsung Galaxy Note 3
    Last Post: 03-26-2014, 05:18 PM
  3. samsung S3 mini RAM
    By Janse9 in forum Samsung Galaxy S3
    Last Post: 03-26-2014, 11:26 AM
  4. Problem with the auto brightness!!
    By diecast10 in forum Moto G (2013)
    Last Post: 03-26-2014, 09:40 AM
