1. Sonya Holden's Avatar
    My mom's Hannspree 10.1" tablet updated google play store today and then everything vanished as if it did a full wipe of the system and even though I had it checked so everything would backup if it got deleted, none of her games did. They're all reset and I don't know what to do. Please someone help!
    03-26-2014 05:44 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! So does it appear that a complete factory reset occurred? Did you have to go through the whole process of logging into your Google account again?
    Do you know if this was a system update, or only an update to the Google Play Store? The latter occurs in the background, while you would have been prompted by the system to accept a system update.
    03-26-2014 06:14 PM
  3. Sonya Holden's Avatar
    Yes I had to login again. From what I can tell it was just a google play store update. There are still files on the internal sd card that were there before.
    03-26-2014 06:19 PM
  4. Sonya Holden's Avatar
    I take it no one has any idea?
    04-03-2014 09:46 PM
  5. srkmagnus's Avatar
    If there was a factory reset and none of the apps were backed up then there's no way to receive those apps with data intact. I also don't think the Play Store update would have reset the device on its own. I'm guessing it was accidentally reset.
    B. Diddy likes this.
    04-03-2014 09:55 PM
  6. B. Diddy's Avatar
    Sorry for the delayed response. Agree with above. If the user didn't accidentally reset the tablet, then it may be faulty system software or hardware. Hannspree is not a very well established tablet maker, which will tend to make their product more unreliable.
    Posted via Android Central App--please excuse the brevity and any typos!
    04-03-2014 09:59 PM
  1. Replies: 24
    Last Post: 06-02-2016, 12:53 AM
  2. Data Manager Icon pops up in notification bar
    By kafox15 in forum HTC One M7
    Last Post: 05-13-2014, 10:35 AM
  3. Help with recovering Galaxy S3 corrupted by Android 4.3 update
    By pmattingly in forum Samsung Galaxy SIII I9300
    Last Post: 04-28-2014, 02:35 PM
  4. Can anyone help figure out what this is?
    By T_Bru in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-18-2014, 02:45 PM
  5. Galaxy s4 loading os help
    By darkangel123elijah in forum Samsung Galaxy S4
    Last Post: 03-26-2014, 04:11 PM
