Results 1 to 3 of 3
    Default Galaxy S3 Mega disconnecting /reconnecting from USB port
    Hi,
    We have an S3 Mega, started using it as a Wi Fi access point for a Gateway Desktop, Windows 7. After 8 hours of flawless operation , the usb starting disconnecting and then reconnecting.
    The check box in the settings screen for USB tethering would uncheck. If you rechecked it it would connect then disconnect and uncheck the box. We moved from a front USB port on the Gateway to a rear USB port and that fixed that problem but after overnight, no WiFi access. Rebooting the computer fixed that. Has anyone had this problem? Other wise it works great, fast.
    Thanks
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,747 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Galaxy S3 Mega disconnecting /reconnecting from USB port
    Welcome to the forums.
    Have you installed updated drivers on your PC. They can be found on Samsung's website.
    Yes we did. We are just trying to save a few buck on buying a wireless access point since the Galaxy's work great for that. Most of the time.
  1. Galaxy S4 says it's charging but it's NOT! Please Help!
    By cberry30 in forum Android 4.4 KitKat
    Last Post: 05-31-2015, 12:22 AM
  2. Samsung Galaxy Note 3 - Different Phone Packaging - Was I ripped off by AT&T?
    By mayconvert in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-30-2014, 10:38 PM
  3. Samsung S3 suddenly started self-rebooting!
    By androidbat in forum Samsung Galaxy S3
    Last Post: 03-30-2014, 04:05 PM
  4. Recovering my Contacts from Mac Book Pro Folder
    By Traian Gabrian in forum General News & Discussion
    Last Post: 03-28-2014, 07:42 AM
  5. Htc M8 or Galaxy s5
    By Jake_15 in forum General News & Discussion
    Last Post: 03-27-2014, 02:45 PM
