Results 1 to 4 of 4
    Garden123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Clock wallpaper on Samsung Ace 2
    I have changed the wallpaper on both the lock screen and the home screen on my Saumsung Ace 2 phone, but the clock persists in staying with the default background (sky and clouds) on the home screen. I have even been into clock settings and changed the wallpaper there, but it seems to make no difference to the home screen. Solution, anyone?
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Default Re: Clock wallpaper on Samsung Ace 2
    The clouds are part of the widget, not part of the wallpaper. The stock wallpaper just happens to be the same color as the background of the widget, so it looks as if the widget it transparent, but it's not. If you drag the widget to another page, you'll see that the wallpaper you put there has no clouds on it.
    Garden123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the reply. But why is the clock background transparent on the lock screen, then? And how do I make it the same on my home screen?
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    The clock on the lock screen isn't a widget in the same sense as homescreen widgets are. You're looking at two apps that look almost identical. About the only way to make the widget transparent would be to retheme or rewrite it.
  1. Replies: 30
    Last Post: 04-11-2014, 03:59 PM
  2. Samsung S3 suddenly started self-rebooting!
    By androidbat in forum Samsung Galaxy S3
    Last Post: 03-30-2014, 04:05 PM
  3. Can't use camera while on a phone call!!?
    By J_galaxy24 in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-27-2014, 04:54 PM
  4. Moto X wallpapers
    By XCalibration17 in forum Moto X (2013)
    Last Post: 03-27-2014, 04:22 PM
  5. How to install APK files on N5?
    By lolchain in forum Google Nexus 5
    Last Post: 03-27-2014, 05:32 AM
