Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Golfdriver97
    Default what does this mean ?
    I was at school for about 8 hours. Casual 1-2 texts but my phone was mostly in my pocket. hli-fi was on but not connected. I get home and my phone's on 71% , is this normal?
    Sent from my SM-N900T using Tapatalk
  2. Thread Author  Thread Author    #2
    Default Re: what does this mean ?
    btw I took this pic at home which is why the wifi is connected.Some days I put on airplane mode and battery is at 94-96% by the end of the day
  4. #4
    Can you show us the breakdown of battery use by app? Also show us the Cell Standby and Time without Signal.
  5. #5
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,756 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    That big gap in the mobile network may be the biggest part of the drain.
    From a Liquid Nexus 5
    Rukbat likes this.
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Aside from what Golfdriver said (the phone keeps looking for a wifi signal, which drains some battery), you have only a few wake-locks. You might want to run wake-lock to see what's waking the phone up, and if the phone is rooted, or you're not against rooting it, use Greenify to hibernate those apps. They'll sleep, but if you run them they'll wake up. (IOW, you don't want to hibernate a text app because you might get a text at any time, but you might want to hibernate something that's waking up every 10 minutes, but you know it's not going to find anything when you're in school.)
    You might also want to run a smart wifi app, so your wifi is off when you're in places where you won't be using wifi - like in school. Apps like Greenify and smart wifi apps take very little power and only wake for a fraction of a second every so often, so they can save a lot of battery.
    However ... 29% in 8 hours isn't terrible, it's just not as good as you can get if you try. You can probably get 2 days before getting down to about 40%, at which point you should charge it.
  7. #7
    It's possible that gap is when the phone was in Airplane Mode. Besides, the battery curve doesn't really dip down during that period--it's afterwards.
    Does your Note 3 have KitKat? If so, you won't be able to run Wakelock Detector or a similar app, because KitKat prevents access to that info unless you're rooted. But if you're still on Jellybean, then I agree with trying Wakelock Detector, as well as running an app like GSam Battery Monitor, which can give you a bit more details about battery usage by apps.
  8. #8
    There are a bunch of things that cause battery drains....
    First, 30% over 8 hours might be a little on the high side, but without looking at the more detail battery usage, it isn't crazy. See all those ticks in the 'Awake' line when your screen is off? That's it doing its thing in the background (checking email, location services, etc). You'd be amazed at how much the phone does stuff when it is off. And those tasks are hard to pick out unless you use an app like Better Battery Stats, or GSam.
    A lot of times people post a graph where that awake is solid, even though the screen is off... that's a sign of a runawy process that is not releasing things and letting the phone go to sleep. THAT will kill even the biggest batteries in a matter of a few hours. See that bit at the start of the graph? See how the phone stays awake for what appears to be,what, the first hour or so? Your screen was only on for a little bit of that time.... so there was something that kept your phone awake for that first part (and you can see the impact by looking at the graph above... the more the phone is awake, the faster things drain...
    What were you doing the first hour or so after unplugging/rebooting?
  1. Verizon HTC One (M8): SIM card error?
    By reykjavik in forum HTC One M8
    Last Post: 07-02-2015, 12:44 PM
  2. Not sure what version my Galaxy S4 is...
    By tigerobrien in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 04-05-2014, 03:31 AM
  3. Replies: 4
    Last Post: 03-28-2014, 11:41 PM
  4. What is the best way to get help?
    By LunaEros in forum General Help and How To
    Last Post: 03-28-2014, 12:06 AM
  5. WiFi Disconnects during voice calls - how to fix this?
    By BlueOrbit in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-27-2014, 04:48 PM
