1. DWesty's Avatar
    Hey all,
    I haven't had any screen issues in the past, but today my tablet randomly decided to go totally black on me. I looked online and some posts mentioned to check if the screen was actually off, or just stuck at 0% brightness. So I got a flashlight and it turned out that I could see the screen in the light of the flashlight, very faintly. I tried to manually change the brightness setting, but that didn't do anything. I tried to go into 'power saver settings', but the 'screen brightness' power saver setting is stuck on and won't uncheck. Restarting doesn't fix it. Plugging it in to the computer or an outlet doesn't fix it.
    I haven't downloaded any applications that override the screen brightness.
    I'm using the Galaxy Note 10.1 (not the 2014 version).
    Any ideas?
    Thanks!
    Daniel
    03-28-2014 03:49 PM
  2. srkmagnus's Avatar
    Hey all,
    Any ideas?
    Thanks!
    Daniel
    Factory reset the device - that'll fix it but will erase your data. So if possible, backup what you need.
    03-28-2014 04:49 PM
  3. B. Diddy's Avatar
    I wonder if the backlight might have malfunctioned, in which case it would need to be repaired.
    Rukbat likes this.
    03-28-2014 05:40 PM
  4. DWesty's Avatar
    The Samsung logo is show at full strength when restarting so I'm not sure that's it.
    03-28-2014 07:17 PM
  5. B. Diddy's Avatar
    Ok, try wiping the cache partition in the Recovery Menu. You won't lose any personal data. Follow the instructions on this support page under "Alternative Method," but make sure that you select "wipe cache partition" instead of "wipe data/factory reset." Then select "reboot system now."
    03-28-2014 07:23 PM
  1. LG G2: Remove lock screen animations?
    By TouchPerception in forum LG G2
    Last Post: 03-06-2015, 02:26 PM
  2. Phone Boots in Loop and Won't go to Lock Screen
    By NathanBellaire in forum General Help and How To
    Last Post: 03-29-2014, 12:03 AM
  3. Pre-Register for the HTC One (M8) at T-Mobile
    By bucketheadmn in forum HTC One M8
    Last Post: 03-28-2014, 10:42 PM
  4. HTC One (M8): Screen Material
    By NoEviL in forum HTC One M8
    Last Post: 03-28-2014, 06:00 PM
  5. Screen Auto Rotating
    By Ian Marshall2 in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-28-2014, 02:12 PM
