After dialing and bringing the phone to your ear, one expects the screen to shut off until it is brought down again, when it will come back on so you can press the hang up button.
Scenario...
His and her identical S4 Android 4.4.2 phones, and two identical cases.
His works fine in this regard but hers does not. With hers, if the screen goes off at all when brought up to the ear, it will not come one when brought back down.
It has become very annoying when the screen does not go off, and your face ends up opening things and navigating sounds are heard during the call even hanging up on the person or muting them at times. We have to pull the phone away from the ear to click the power button to manually turn it off.
The same phone works fine when it is not in its case. The same phone works fine when it is in HIS case. His phone does NOT work in her case.
We have determined that HER case seems to be the common denominator. Her and I love our matching cases and would prefer to find an easy way to fix to this rather than go shopping for two new identical cases.
What was tried to correct the problem...
Looking at both cases apart from the phones side by side on the table, I dont see anything different among their three pieces.
I have compared all the settings side by side and find nothing that could change this. I have pulled the battery.
I searched for "gyroscope calibration" and found our phones dont have that setting where others describe it would be.
Since I am not an Android expert, I cant be sure what exact version of the Samsung Galaxy I have nor the exact OS other than 4.4.2, and it is likely the least expensive model S4 they make AT This Time. If you need this information and can guide me on how to determine this information exactly, by all means do tell..
note: this image is a close representation of our cases but does not reflect the exact cases that we have.
Scenario...
