1. AlrightyThen's Avatar
    I have a Samsung Stratosphere and yesterday my phone started glitching. The glitching consists of launching the search function 30 times a minute and activating the voice-to-text feature over and over. It launches it, then closes it, then launches it again none stop. I can't do anything with my phone at this point. I've put the phone in safe mode and it does the same thing. Is it a hardware issue? I've dropped it 4 times and I've had it for 1 year and 7 months.
    03-30-2014 06:41 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Weird stuff. A few things you can try:
    1. If you have an SD card, try removing it and rebooting. Sometimes a corrupt SD card can cause the phone to misbehave.
    2. Although it's unlikely, sometimes a failing battery can also cause problems. If you have a spare battery around, try swapping it out.
    3. You can also try wiping the system cache partition in the Recovery Menu, which can sometimes help with issues like this. You won't lose any personal data. Follow the "Alternate Method" in this link, and make sure to select "wipe cache partition," NOT "wipe data/factory reset." When it's done, select "reboot system now," and see if the problem is better.
    03-30-2014 09:41 PM
  3. AlrightyThen's Avatar
    Thanks for the response B. Diddy.
    I removed the SD card and rebooted, but it's still glitching.
    I don't have a spare battery so I will try that when I find one.
    Clearing the system cache didn't solve it either :/
    03-30-2014 10:35 PM
  4. Vsweety's Avatar
    Assuming it is a removable battery powering down the device and removing the battery for 10 minutes before replacing it and powering the device up again is also something you can try.
    You don't have to wait for a spare battery for that.
    03-31-2014 06:05 AM
  5. AlrightyThen's Avatar
    I did that, nothing.
    I also did a factory reset and the glitching is still occurring. Is the phone just broken?
    03-31-2014 05:36 PM
  6. Rukbat's Avatar
    Bring it to a Best Buy store and find or ask for the Samsung kiosk. Tell them what's happening and ask if they think a reflash might cure it. (You'll lose all your data so back everything up. And you'll probably have to pay something for the reflash, since it's out of warranty. If they agree to, ask how much it will be BEFORE they do it.)
    B. Diddy likes this.
    03-31-2014 10:12 PM
  7. AlrightyThen's Avatar
    Alright thanks, I'll try that tomorrow.
    03-31-2014 11:07 PM
  1. How Install Greek Language on android menus?
    By jdeim in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 04-15-2016, 06:34 PM
  2. Why won't Android update for this?
    By rastergrafx in forum Samsung Galaxy Tab 3
    Last Post: 04-05-2014, 06:23 PM
  3. Annoying Android "Feature"
    By tem#AC in forum Samsung Galaxy S4
    Last Post: 04-01-2014, 03:16 PM
  4. KG G2 after OTA to android 4.4.2 wifi flash
    By sgavriel in forum LG G2
    Last Post: 03-31-2014, 01:19 AM
  5. Android 4.4.2 Dialer "Unknown Caller" from future
    By aaronlam in forum Android 4.4 KitKat
    Last Post: 03-30-2014, 09:47 PM
