1. Phantom T5's Avatar
    Hi Guys,
    I purchased a Minix Neo X7 and it came with xbmc, I'm having trouble importing video from my hard drive to xbmc. When I go to add video, I locate the movie folder and then add it, my movies don't show up. What am I doing wrong?
    I'm a newbie with xbmc.
    Any help would be much appreciated
    03-31-2014 06:00 AM
  2. hkeiner's Avatar
    Just a guess as to your problem...
    When you add a new video folder one of the screens asks you to select the type of folder it is. You need to select 'movie' or 'tv show' ,as appropriate, or the videos will not show under the Movie or TV Show tabs. The new folder will still show up under the Video tab though.
    03-31-2014 05:25 PM
  1. Tap Tower - A simple game with realistic physics
    By Levent Aymelek in forum Android Apps
    Last Post: 07-03-2014, 11:42 PM
  2. Help ! Can't change the images of all songs.
    By LeApple in forum Samsung Galaxy Note 3
    Last Post: 04-01-2014, 11:59 PM
  3. Replies: 5
    Last Post: 04-01-2014, 11:19 AM
  4. Knock on with nova
    By cootiesboy in forum LG G2
    Last Post: 03-31-2014, 04:50 PM
  5. Help With Pre-Rooted Tablet
    By Shnoogans37 in forum General Help and How To
    Last Post: 03-31-2014, 01:29 AM
