1. Sletox's Avatar
    So if you read the first story Here. You know the first part.
    So now I kept restarting my phone beause i thought i would get back original google play and thought it was prob a easy fix but it turned to be something BAD as i went to "Volume up, home bottom, and power". There I started to wipe out "data/factory reset, wipe cache partition". After seeing i didnt get my google play I went to internet and searched for a APK google play , i found it and installed it but it crashed all the time. So after that I went to SuperSU app my rooted app and pressed permentaly remove root and after that i went back to "Volume up, home bottom, and power" and I went then to "mounts and storage > and I formated /system, /data, /data and /data/media (/sdcard).
    After that i realized my phone wont turn on and since then i havent manage to turn on my phone, i wanted to turn in my phone to the fabrice i bought from but i relizead that i have a rooted phone and that they will not fix it as my warrenty is gone.
    SO PLEASE HELP ME GUYS, I NEED A HAND IN NEED. THE ONE FIXING MY TROUBLE WILL BE REWARED 50$ through paypal.
    03-31-2014 11:57 AM
  2. Johnly's Avatar
    Good luck. We do not ask members to pay for advice, nor do we condone that. Donation links must meet the forum guidelines.
    04-01-2014 01:16 AM
  1. Replies: 16
    Last Post: 12-17-2014, 12:48 AM
  2. Replies: 3
    Last Post: 07-31-2014, 02:15 PM
  3. Phone screen
    By fourhour in forum Verizon Galaxy S III
    Last Post: 03-31-2014, 01:20 PM
  4. Encrypting Files on Moto G, implications?
    By shmotog in forum Moto G (2013)
    Last Post: 03-31-2014, 11:50 AM
  5. Music Purchased On Google Play
    By MacSparkle in forum Samsung Galaxy S4
    Last Post: 03-31-2014, 11:41 AM
