smdl2tmp1.asec !!!!!!!!!
Guy Tagger
3
ok...(sorry for the bad english) i try everything..
i cant save photos or install games on the sd card i cant format it i cant delete the smdl2tmp1.asec cant delete nothing i just can listen to my music and watch what i have on the sd card nothing else
i try cmd to format it i tried em format from my galaxy i tried apps to format everything just crush and exit i don't know what wrong my sd card works but dot works on the same time..:S
anyone help me to format sd card or delete thous things!! please helppp!:D :'(
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,581
4,724
113
Welcome to Android Central! Can you tell us the make and model of your phone, and the version of Android it's running?
One thing to try would be to unmount the card, remove it from your phone, and insert it into your computer. Then back up all of the data and reformat the card. Put your data back on the card, and try it again.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,581
4,724
113
So you're saying you actually backed up the card and reformatted it in your computer, right?
How about trying a different SD card?
newprvn
