Hi,
I was not sure in which forum section I should post since many of them seem to match my post! Don't hesitate to redirect me to the right section.
I need help with merging SMS between 2 Android devices. Both are Samsung Galaxy S4 running Android 4.3 or 4.4.2 (I might update to 4.4.2 soon), none are rooted. I have been using G Cloud Backup but it does not seem to offer a merge option. It's a one-shot, one of the device won't be used afterward.
I don't know in which format SMS are stored on the device... maybe these format would be easy to merge? Or maybe there is an app that could do that (backup phone 1, restore it on phone 2 with a merge option...)?
What happened is that I received SMS on both devices and I'd like to merge them.
Any idea is welcome! Let me know if you need more information.
Thanks!
Thanks!
