Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By gow75
    Default Type Scands text on english Keyboard
    I need some assitance typing Scands text like on a PC
    LT+0229 =
    ALT+0197 =
    ALT+0228 =
    ALT+0196 =
    ALT+0246 =
    ALT+0214 =
    how do i do this using Better Keyboard, I bought better keyboard long ago and use it all the time please help.
    also the reason why i need scands is because I am trying to rename a folder so that my music playlist will see it as the artist they are not as Unknown!.
  2. #2
    Default Re: Type Scands text on english Keyboard
    Welcome to Android Central! I can't help you with Better Keyboard, but you can change Google Keyboard to many different languages. Go to Settings>Language & input, tap the settings icon next to Google Keyboard, then Input Languages, then uncheck "Use System Language," and then select the Scandinavian language you need from the long list.
    With Better Keyboard, you could check its settings to see if it has a similar option.
    thanks B diddy.
    B. Diddy likes this.
  1. Bluetooth Keyboard Disconnecting Issue (Has anyone found a solution yet?)
    By SpookDroid in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-03-2014, 02:03 PM
  2. Moto X Camera Stuck on Front View
    By TechRaider05 in forum Moto X (2013)
    Last Post: 04-02-2014, 10:00 AM
  3. Unlocked HTC One (M8) for use on AT&T
    By mrjack in forum HTC One M8
    Last Post: 04-01-2014, 12:08 PM
  4. Software Update Causes Text Delay
    By OpenBSD in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-01-2014, 11:09 AM
  5. Widgets on Nexus 10 VERY slow to load
    By eppack in forum Google Nexus 10 Tablet
    Last Post: 04-01-2014, 11:03 AM
