1. sajisme's Avatar
    I have my previous phone which is a Droid Bionic with Jelly Bean that I do not use any longer and does not have a number associated with it. I would like to leave it in my car so I can use it as lo-jack in case my car gets stolen. I switched it on and tried locating it using Android Location Tracker with the Location Service turned on the phone. The tracker is not able to find the location of the phone.
    Does the phone need to be connected to 3G or wi-fi for location service?
    04-01-2014 12:14 PM
  2. LeoRex's Avatar
    Yep.... it still needs to 'phone home' with its location for it to work. If the SIM is pulled, then it becomes a portable wifi device.... which doesn't help you in your car.
    04-01-2014 12:26 PM
  3. dpham00's Avatar
    You can use wifi if your car has a hotspot built in
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    04-01-2014 01:29 PM
  1. [FREE][LiveWallpaper][Android] Very Simple Live Wallpaper
    By mckmck in forum Wallpapers, Ringtones, and Themes
    Last Post: 04-07-2014, 09:12 AM
  2. Android Wear and skinning...
    By zavye3100 in forum Android Wear
    Last Post: 04-02-2014, 06:15 PM
  3. Android music album art missing
    By gow75 in forum General Help and How To
    Last Post: 04-01-2014, 11:22 AM
  4. Official Emotion UI 2.0 + Android 4.4.2 KK
    By ChinaOperatingSystem in forum Huawei Ascend P6
    Last Post: 04-01-2014, 09:59 AM
  5. Android application of Outlook
    By Richard Crane in forum Android Apps
    Last Post: 04-01-2014, 06:47 AM
