1. newandroiduser416's Avatar
    Hi All,
    Wondering if anyone can experienced this...I'm trying to edit a face photo.
    When i go into edit mode of my picture, I select "portrait". The yellow square box appears on the face of the person so that tells me the face is detected. Then I select "beauty face" so I can edit parts of the face ie" nose , mouth etc and the yellow box moves to a random part of the picture (away from the face).
    This never happened before until I installed the latest update to my phone.
    Anyone else have this issue? Is there a place I can log my issue so Samsung is aware? (Not that they will do anything about it....)
    04-01-2014 03:53 PM
  2. skullsmasher86's Avatar
    I am going through the exact same problem after installing the latest update
    04-07-2014 05:23 PM
  3. nyc_lala's Avatar
    I just got the S5 and beauty face is definitely not working. One of the reasons I converted to Samsung was for the camera and all the different modes. I'm very disappointed and wishing I had my iPhone again.
    04-17-2014 10:46 PM
  4. joleigh's Avatar
    Hey guys! I have the Samsung Galaxy Mini 3, but I think I might be able to help. For some reason, Beauty Face was turned off on my phone - so you may want to check to see if it's turned on.
    Go to Settings
    Go to More
    Go to Application Manager
    Here you'll have 4 options: Downloaded, On SD card, Running, All
    Scroll over to ALL
    Scroll all the way to the bottom and this is where your "turned off" apps are
    Click on Beauty Face and turn on
    Hope this helps!
    - - - Updated - - -
    Go to Settings
    Go to More
    Scroll over to ALL
    Hope this helps!
    07-05-2014 12:10 PM
  5. Sara_80's Avatar
    Tried to follow:
    Go to Settings
    Go to More
    Scroll over to ALL
    I scrolled over to ALL and looked through the list but unable to locate Beauty Face.
    Really want to get my camera working 100% this is very frustrating.
    If anyone else got the above directions to work, maybe provide a screenshot of what you turned on?
    09-30-2014 03:32 PM
  6. karylsugar's Avatar
    Hi All,
    05-15-2015 06:58 AM
  7. karylsugar's Avatar
    exactly same problem. Had i have known i shouldn't have upgraded mine. How do we get this resolved
    05-15-2015 07:00 AM
  1. SEIDIO OBEX Waterproof Case for the Samsung Galaxy Note 3
    By seidioseidio in forum Samsung Galaxy Note 3
    Last Post: 01-24-2015, 07:53 AM
  2. how to change date on the Beautiful Widget app??
    By elykoj in forum Android Apps
    Last Post: 01-04-2015, 12:01 PM
  3. Wi-fi not working on RAZR HD
    By lkct01234 in forum Droid RAZR HD
    Last Post: 04-09-2014, 10:17 PM
