1. Bilal Saleem1's Avatar
    Hello friends !
    I'm using android tablet Proscan PLT1066.
    One day my sister playing game and it turned off suddenly, when we turned it on it asks for re setup and google account like we bought it new.
    Since that day it won't shutdown I have to hold the power button long to turned it off and every time we turned it on it starts very slow take time and every time ask for RE SETUP asks for language, time and Google account. It won't download any thing from play store , Charge slow take almost 8 hours.
    Please tell any solution if any body ever through this problem and can help ?
    04-03-2014 04:32 AM
  2. Golfdriver97's Avatar
    Short of reflashing the stock ROM, I don't know what to do. I tried searching for the files but came up with nothing.
    04-03-2014 08:45 AM
  3. Bilal Saleem1's Avatar
    So u mean my tab is waisted ?
    How could these thing be so sensitive
    04-03-2014 09:22 AM
  4. B. Diddy's Avatar
    ProScan is one of those companies that sells very cheap Android tablets--these kinds of devices are notorious for poor build, buggy software, and little support. They're cheap, but unfortunately, you only get what you pay for. In the future, try sticking with well-established manufacturers, like Google, Asus, Samsung, Acer, Lenovo, or even Hisense. These companies have good track records and support, and a bunch of them make tablets that are quite inexpensive even when brand new. You can get even deeper discounts if you look for older refurbished models (for example, you can often find the first generation Nexus 7, still an excellent device, for about $100).
    04-03-2014 12:22 PM
  5. Bilal Saleem1's Avatar
    Any solution that can troubleshoot this problem so my tab can work normally ?
    04-05-2014 06:18 AM
  6. Perer's Avatar
    Yes having same problem with my Pros can PLT1066.
    My solution to never shutting down? I don't shut it down. I give it a sleep time of 5 minutes and never give it a shutdown.
    Follow through on the hard reset questions. That's the only way you are ever going to be able to use it.
    05-01-2014 11:56 AM
  7. B. Diddy's Avatar
    Are you able to do a full factory reset?
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    05-01-2014 12:16 PM
  8. Perer's Avatar
    Full factory reset does not help. I tried it two or three times. Still can't shut down normally. Also. Full factory reset screws up the storage. Claims no space left. So all I use it for is whatever I had. Can't download any new apps. It seems the operating system gets screwed up somehow. My guess is automatic updates are the culprit.
    This is my second unit. I returned the first one because it wouldn't boot. If this one fails I will just salvage the battery. Welcome to the cheap tablet, no support world.
    Also won't allow SD card install and headphone jack stopped working.
    It's a real learning experience.
    05-01-2014 06:49 PM
  1. Replies: 5
    Last Post: 09-03-2014, 03:34 AM
  2. LG G2 GPS & Magnetic Field Troubles
    By tvdberg in forum LG G2
    Last Post: 04-07-2014, 03:29 AM
  3. Trouble sending a video with my LGg2
    By Jeff Smith13 in forum Motorola Droid Mini
    Last Post: 04-03-2014, 07:19 AM
  4. Trouble Viewing Network Cameras
    By DroidCentralMember in forum Verizon Samsung Galaxy S4
    Last Post: 03-28-2014, 11:40 AM
  5. Samsung Galaxy S4 Firmware Update Trouble
    By Miki Vermeulen in forum General Help and How To
    Last Post: 03-28-2014, 08:34 AM
