Results 1 to 4 of 4
    Default Flash player on Kit-kat......How to?
    Updated my htc one software to kit kat, realizing now that there is no flash player. Any suggestions? Im running-4.06.651.9
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Default Re: Flash player on Kit-kat......How to?
    Quote Originally Posted by treiber67 View Post
    If you want flash in your browser, you can get it with Dolphin Browser or Maxathon Browser.
    https://play.google.com/store/apps/d...k.TunnyBrowser
    https://play.google.com/store/apps/d...com.mx.browser
  3. #3
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    You can also install the Adobe Flash apk as seen on the Adobe Website and Android Central.
    Adobe Community: How do I manually install Flash Player on my Android device?
    http://www.androidcentral.com/how-ma...android-device
  4. #4
    If you had it before the update, you should be able to find it in Play by going to the my apps section, then to the "all" tab at the top. That shows every app ever installed, and worked for me when side loading from the Adobe website failed. An AOSP browser will also show flash too.
  1. Moto X: To Tether or not to Tether that is the question
    By oldDummy in forum Moto X (2013)
    Last Post: 04-05-2014, 09:10 AM
  2. Replies: 7
    Last Post: 04-05-2014, 07:14 AM
  3. Galaxy S3: Pink splatters on my lcd
    By jubleve in forum Samsung Galaxy S3
    Last Post: 04-04-2014, 08:26 AM
  4. Pink splatters on my lcd
    By jubleve in forum Sprint Galaxy S3
    Last Post: 04-03-2014, 11:28 AM
  5. Pink splatters on my samsung gs3 lcd
    By jubleve in forum Samsung Galaxy S3 I9300
    Last Post: 04-03-2014, 09:35 AM
