Results 1 to 6 of 6
    ofcourse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problem During Flash Now Can't Open My Tablet
    I was using Rockchip Batch Tool to install a rom to my tablet.Everything was good.I pressed switch then restore and it said restore done succesful 1.
    According to documentation coming with my tablet it says in the last step is should say "loading firmware" but it didnt.Waited for half an hour but still nothing then i disconnected my tablet from pc.Now it is not responding.When i press power button screen comes to life its still black.
    Somewhere else i read that i should connect my tablet in recovery mode and install drivers but my documentation said just power on and plug.I think drivers werent installed properly.
    So is my tablet dead?What can i do?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,066 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Problem During Flash Now Cant Open My Tablet
    What kind of tablet is it?
    ofcourse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Golfdriver97 View Post
    Its ainol aurora 2.It uses android 4.1.1.
  4. #4
    Posts
    Global Posts
    33,066 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I am not sure what to suggest. Reflashing a stock ROM is an option, but the question would be finding the files if they are even available. Often, when flashing anything to a device is interrupted, that is bad news.
    ofcourse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But i cant open recovery mode can i reflash stock rom?I have stock rom img file.
  6. #6
    Posts
    Global Posts
    33,066 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    If you had USB Debugging checked before the tablet went out (I am guessing so if you were using the PC tool), then you should be able to use ADB (Android Debug Bridge) to reflash the Stock ROM.
  1. Problem with contacts
    By janpietjoris in forum Google Nexus 5
    Last Post: 04-05-2014, 01:24 PM
  2. Replies: 1
    Last Post: 04-05-2014, 10:34 AM
  3. i try to update my android put ...
    By waleed az in forum General News & Discussion
    Last Post: 04-05-2014, 07:40 AM
  4. i want to use fb sdk on my application ...
    By waleed az in forum Google Nexus 5
    Last Post: 04-05-2014, 06:54 AM
  5. APN Problem
    By peter21 in forum Android 4.4 KitKat
    Last Post: 04-05-2014, 05:28 AM
