Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By srkmagnus
  • 1 Post By smallfrys
    smallfrys's Avatar
    Posts
    Global Posts
    26 Global Posts
    Default My Phone/Hangouts is Driving Me Crazy with Notifications. Help?
    Is there an app or method that would mute incoming sounds/vibration for Hangouts/SMS until I dismiss the notification?
    I'm always getting short texts from people instead of one long one. So my phone dings/vibrates for each one. I want to know about the first one, but not every one after that, at least until I put my phone down again.
    If it was possible to do this on a per-contact basis, that would be even better.
    I'm fine with rooting my phone or whatever else I need to do to fix this.
    Sent from my Nexus 5 using Tapatalk
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: My Phone/Hangouts is Driving Me Crazy with Notifications. Help?
    The Hangouts app is limited on settings when it comes to sms. Take a look at the third party clients and see if anything offers those settings. Otherwise, I don't know of anything else that would work.
    smallfrys likes this.
    smallfrys's Avatar
    Posts
    Global Posts
    26 Global Posts
    Thanks, I'll try that first. I found this for Tasker. Just not sure if I can make it specific to Hangouts. Also, Tasker would be a time sink for me.
    http://tasker.wikidot.com/silencefortextconversation
    srkmagnus likes this.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by smallfrys View Post
    I pretty sure Tasker would work fine. But as you mentioned, will require time to setup right. Good luck, let us know how it goes.
  1. any call blocker that works with 4.4.2?
    By shinydiscopants in forum Moto X (2013)
    Last Post: 02-21-2015, 05:01 AM
  2. Verizon Note 3: I need help turning off automatic OS updates
    By Evilguppy in forum Samsung Galaxy Note 3
    Last Post: 02-06-2015, 09:08 AM
  3. i need to make my android root access ...
    By waleed az in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-13-2014, 05:56 AM
  4. any help there ...
    By waleed az in forum Google Nexus 5
    Last Post: 04-05-2014, 08:16 PM
  5. Replies: 3
    Last Post: 04-05-2014, 01:01 PM
